Tool Talk Discussion Forum
Converter Box for Lincoln SA200 F163 Welder
pollock
08-06-2006 11:10:33
I need a converter box on my Lincoln SA200 F163 for the DC receptacle on the welder. I want to convert the 110DC to 110 AC so that I can run other electrical equipment from the welder. I was told a "Converter Box" is available. I would appreciate any help - many thanks,
Mike
T_Bone
08-09-2006 01:30:23
 Re: Converter Box for Lincoln SA200 F163 Welder in reply to pollock, 08-06-2006 11:10:33
Hi Mike,
I've never seen a AC adpter for them. Have you researched the Lincoln archives? You might DL the service manual to the newer SA200 or SA400 and see just what componets are in the AC side.
You can take a common transistor based 2000w inverter and supply the amperage needed to run the inverter from the welding leads. That would be about 170amps at 24vdc or well within the SA200 capabilitys.
That would give you a modified sine wave 115vac @ 18amps and good for just about any home type appliance.
What are your going to run on the AC side?
T_Bone
pollock
08-11-2006 15:58:46
 Re: Converter Box for Lincoln SA200 F163 Welder in reply to T_Bone, 08-09-2006 01:30:23
Thanks so much,T_Bone. This is very helpful - cheers,
pollock
Tramway Guy
08-08-2006 20:40:32
I did a google search for "inverter 120VDC" and got several promising results. 120VDC is a common voltage for Uninterruptible Power Supplies, where a large bank of batteries provides backup to a group of important computers or communication devices...
dr.sportster
08-08-2006 14:27:49
Tools like Milwaukee drill etc.with universal wound motors will work on the DC outlet.Or install a switch and have wife flip it sixty times a second.
pollock
08-08-2006 17:06:30
 Re: Converter Box for Lincoln SA200 F163 Welder in reply to dr.sportster, 08-08-2006 14:27:49
Gee thanks dr.sportster, but two problems:
a. I am aware that I can run anything with brushes from the welder, but I am off the grid - no AC at all.
b. I am recently divorced - real messy
If anyone can help, I would greatly appreciate it. I know that they used to make these conversion boxes - peace, pollock
dr.sportster
08-08-2006 18:26:11
 Re: Converter Box for Lincoln SA200 F163 Welder in reply to pollock, 08-08-2006 17:06:30
Sorry.If it makes you feel any better I just gave stupid advice on an antique bike site about the wrong size tap.I will shutup now.
pollock
08-11-2006 16:01:34
 Re: Converter Box for Lincoln SA200 F163 Welder in reply to dr.sportster, 08-08-2006 18:26:11
No problem - I think I got up on the wrong side of the bed that day. Your comment was really funny - keep up the good work - cheers,
pollock
Fred Martin
08-07-2006 09:16:42
I always bought my drills and grinders etc. so that they would run on AC or DC and of course an incondescent bulb doesn"t matter...so I never had that problem. There is such a thing as a 12 volt inverter...that takes 12 volts and goes thru and comes out as 120 AC...but I never heard of a converter for the welder. Learn something every day. Fred OH
johnlobb
08-06-2006 17:07:14
Hi! I have exactly the same welder and the same problem- no AC power. I would like to know the answer to your question also. John L.
