Tool Talk Discussion Forum
Kohler Power Pro Generator
generator troub
08-01-2006 18:49:30
I got an old Kohler Power Pro 5000W Generator - the one with the Kohler K301 engine that is only showing 2-3 volts in what should be a 120v socket. The 220v socket shows 5 volts.
Any suggestions?
Terminal due to the cost of fixing?
Any leads on a good manual
woodbutcher
08-02-2006 03:45:20
 Re: Kohler Power Pro Generator in reply to generator troubles, 08-01-2006 18:49:30
I have a 12hp Kohler of the same vintage on my Hobart portable welder. I got a manual from Kohler. I recommend checking out the website www.hobbytalk. There are people at that site who have dealt with similar problems.
To excite the windings on my welder I have to continue to hold the starter button in for 15 seconds after the engine reaches full rpms.
Butch
Davis In SC
08-01-2006 20:57:16
Do a search, there have been several discussions here, concerning "Flashing" a generator to excite the coils. Requires using an electric drill motor.
Generator Troubles
08-02-2006 05:51:50
 Re: Kohler Power Pro Generator in reply to Davis In SC, 08-01-2006 20:57:16
I've flashed it using a double mail plus into a 120v outlet in the garage.
It worked a year ago but not now
Bob
08-02-2006 08:06:43
 Re: Kohler Power Pro Generator in reply to Generator Troubles, 08-02-2006 05:51:50
That's a NASTY way to "flash" a generator"! I'm surprised you didn't have a BIG spark at the plug, or trip a breaker, BECAUSE when you connect two AC current systems together that are not at the EXACT frequency, and in-phase, nasty things happen! (Which is probably how the term "FLASH" came to be!)
Here's the link the other poster mentioned, to a SAFE way to "flash" the generator:
