Tool Talk Discussion Forum
hay storage trailer
teamjunkyard
07-31-2006 10:48:22
I am going to store small bales in a semi van trailer,dry inside with plate steel over wood floor, should i put pallets on floor or boards to let air flow around? thanks
mjbrown
07-31-2006 17:40:21
 Re: hay storage trailer in reply to teamjunkyard, 07-31-2006 10:48:22
If your hay is good and dry you won't have any problem. I use pallets on the ground where direct contact causes moisture from the ground to be wicked up into the bales. In a truck body like you described that shouldn't be a problem.
old
07-31-2006 11:17:58
Well if its still on its wheels and all it should be ok to put it right on the floor. Those old semi trailors aren't all that tight on the floors and you should have a good air flow becuase of that. We are useing one like what your talking about and put the hay right on the floor.
