Tool Talk Discussion Forum
campbell hausfeld wire welder
bil b va
07-30-2006 14:14:38
anyone have experience with their flux core wire welder ? if i had a boat i would probably make a boat anker of it . i traded neighbor an old 1 hp aircompressor for it . it was purched new in 2001 is like new and i think it has the original roll of wire on it .i have been stick and ox/ ace welding for about 35 years in maintenance after taking night classes . had some mig and tig training then .i am intrested in welding thin metal (body repair ) and so far not muck luck in practing on scrap . any advice appreciated . it has heat selection of low 65 amp/high 70 amp with wire speed adjustment . seems too hot for thin metal . if i increase the travel speed i get very little weld deposit and if i slow the travel i get hole burned through .
Ken Crisman
07-30-2006 18:09:03
 Re: campbell hausfeld wire welder in reply to bil b va, 07-30-2006 14:14:38
I'm no welder , persay . But I can do ok for myself . I was having problems with my mig once not working correctly . What they found was that the wire gets a rust film on it from just sitting in the garage & not used much . They cleaned the wire back a bit & put a felt lubricator pad in the machine so that the wire goes thru it before the tube . Now it works great again .But then again I have a Miller Crickett 110 . They don't even make this jewel anymore . I could've sold that thing several times . I hope I was of some help .Good luck & God bless . Ken
TimV
07-30-2006 16:56:09
bill b: Without knowing your level of wire experience, it's hard to judge whether I'm aiming too high or too low here, but one tip would be that welding sheet metal is nothing like "regular" welding. The order of the day is weld, stop, weld, stop, etc. No one but a VERY experienced welder can just lay a bead down on sheet metal, and even the ones that can usually don't due to warpage. A lot of sheet metal welding is done as "stitch" welding--weld an inch, move an inch, weld an inch, move an inch, then come back and fill in the gaps. Also, as NcNe mentioned, a flux-core welder isn't the optimal setup for doing sheet metal. However, if that's all you've got, it certainly can be done, it's just harder. Thinner wire is better, at least in my experience. I use 0.023" on all of my body work with my Hobart 135. Make sure your guides, tips and tension are correct, then try welding on thicker stock until you get it down, then move down in thickness. Also, be careful on what you use for scrap panels. It doesn't take very much rust to thin out the metal to the point where you're constantly blowing through, which can be extremely frustrating. Select good areas, clean them up nice and shiny, then go to it.
Tim Casbolt
07-30-2006 16:29:32
Flux core wire is deep penetrating, making sheet metal welding a challenge. Works ok on thicker stuff.
bil b va
07-31-2006 05:14:47
 Re: campbell hausfeld wire welder in reply to Tim Casbolt, 07-30-2006 16:29:32
tim i think you have pin pointed my main problem . my first thought was the arc was too hot for thin metal . apparently this machine is for the dip-transfer method . the spray method is better suited for thin metal . the machine is wired for D.C.straight politary which means 2/3 of the heat is released at the work . i may try changing the poliarity in the machine to get D.C. reversed poliarity . i am only intrested in welding thin metal with this machine . i have a portable 200 amp d c machine , a 235 ac buzz box and oxy /acetelene . hopefully steve us alloys and t bone will give me their thoughts . if i had more need i would buy what is needed . guess i could turn it into a battery charger
NcNE
07-30-2006 15:26:39
Although I am not totally familiar with your welder, I will make a few recomendations. The first is a little more simple. Do some research and try to find the flux-cored wire that would best suit your situation as there are many different wires just like there are stick electrodes. I will look in my books and see if I cant come up with the right wire for you. If that doesnt work, I would suggest a shielding gas kit. Flux-core works an awful lot like stick welding, except for the flux is located on the inside of the wire instead of the outside. This being said, flux-core needs to be ran at a little higher temp than regulare mig wire. By adding shielding gas such as CO2 or C25 (CO2,Argon mix) and switching over to mig wire you can lower your temp and in most cases lay a good bead without blowing holes in your material. If you go with this option, my best advise would be to contact a welding supply store. They can set you up with the proper gas, and can help you select a wire type and diameter that is right for the job. One thing I might add would be to make sure that your contact tips match the diameter of your wire, obviously .035" wire wont feed in a .030" tip and if you run too small of wire though a tip you will have problems with the wire sticking to the side of the tip. Hope this helps. Nick
