Tool Talk Discussion Forum
What chainsaw to buy?
Kent Morris
07-29-2006 15:25:03
I'm not a lumberjack nor a commercial tree trimmer. Just a guy that needs a reasonably good chainsaw at a reasonable price for cutting fire wood and triming trees around the yard.
My last experience was a Poulan Wildthing. Starts good, runs good but can't keep the bar tight. It has square headed bolts seated in the plastic frame for mounting the bar. The muffler heats the plastic causing it to soften and allowing the bar bolts to pull into the plastic. When I bought it, I assumed the frame was heavily painted pot metal or aluminum. Never dreamed the main frame would have been made from molded plastic. I have come to the conclusion that brands names are no longer an indication of quility. Too often now days an old reliable brand name is stuck a cheap piece of junk. Remember the days when names like Cub Cadet and Craftsmen ment something.
Any suggestions by make and model for a good 18-20" chainsaw under $300?
DJL
08-06-2006 00:13:06
 Re: What chainsaw to buy? in reply to Kent Morris, 07-29-2006 15:25:03
Kent,
I hate to get in the brand war discussion, but I have to say STIHL. My dad cuts alot of firewood, as we have alot of trees on our farm and he has a woodburning furnace that heats his house. He's ran Pioneers, Partners,Craftsmans and most recently Poulan Pro's. He never wanted to spend the money for a Stihl. Guess he was happier with throw-aways. Anyway, I bought a small Stihl with an 18" bar, can't recall the number off-hand, maybe a 277? Anyway, it's a medium duty saw for heavy homeowner usage or lots of firewood cutting. That was 3 years ago.....Dad won't let me have the thing back, because he likes using it so much. I think it was around $375. Spend just a bit more money, and you'll be happy.
steve in in
07-31-2006 09:26:06
Just a story: Customer Service is everything!
A few years back I bought a Stihl Farmboss. A friend had a farm that I was taking care of. He had paid a company to come in and take down about 20 trees. Most of the trees were walnut, some were hackberry. Anyway.
He told me I could have the logs. At the time I didn"t have the money to pay to have them milled, because I was jobless. So I left the logs laying until I got a job. So being the procrastinator that I am, the farm finally had to go up for sale before I decided to do anything about the logs.
I hired someone with a portable saw mill to come cut up the logs into lumber. Meanwhile I needed to cut some of the logs down and then would need to cut up the slab wood and whatever I didn"t have milled. So I visited my local Stihl dealer.
I bought the Farmboss and got a deal on a case, glasses, hat and gloves for $15 extra. So I used the new chain saw to start cutting the logs but found it needed sharpening about every 5 or 6 cuts. Not ever used a chainsaw much, I thought, wow, this stinks, instead of "something must be wrong". So when the sawmill got there I had to saw a log while the sawyer waited. The chainsaw hardly wanted to cut even though I had just sharpened it. He said, I"ve got a saw in the truck with a sharp chain. I knew something was wrong then.
So it was Sunday by the time I went back to the farm to finish up and had several logs to saw yet. I had to get them out that day because closing on the farm was the next day. Nothing like procrastinating. Anyway, I took the bar and chain off and looked at the sprocket and found the chain size and the sprocket size did not match. You can imagine what that does to all the parts.
Since it was Sunday, the dealer I bought the saw from was not open. The local Ace hardware was though. So I bought a new chain, sprocket and a smaller bar and finished the job with a lot less cussing and a lot less sharpening.
The next day I took the original chain, sprocket and bar to the dealer where I purchased the saw. They offered to either pay for the replacement parts I had just purchased or to give me new parts. I don"t know why I did it now, but I have a new bar chain and sprocket sitting in a cabinet at home just waiting for the others to wear out.
My guess is that in 30 years they will still be sitting there.
Anyway, once the problem with different chain and sprocket sizes was ironed out, the stihl has been a great saw. Not a bit of trouble out of it. Of course it hardly ever gets used, but it fires up and cuts well when I do use it.
cj3b_jeep
07-31-2006 06:37:46
I'd stick with the Stihl/Husky line if you're in the U.S. I don't think Jonsred is a big brand here so they don't have much in the way of support. I think that's different in Canada. I have two Stihl saws, an 021 I've had for 16 years and a Farmboss (029) I've had for three, both are great saws and have never given me a lick of trouble. I think you'll find that all saws have a plastic body, any kind of metal would be just to heavy. I was surprised at how cheap a Farmboss can be had v.s. a Poulan or something similar at a big homestore. Also, buy it from a good dealer with good support in case you need anything later.
Pitch
07-31-2006 03:03:01
Probably to far down for you to read this now.
I,m like you, I needed a swa to use several times a year. I bought a yellow Poulan Pro, have had absolutely no issues with it. Yes there are much better saws built and they all are mentioned below, but I have to balance cost with amount of use. The Poulan is 8 years old sits out in the shed and fires and runs every time i need it. When I was clearing my place that saw took down 22 40 ft black walnuts and cut every one into stove wood.
I did spend the big bucks on a Stihl Trimmer, but that thing gets used every weekend for a coupla hours at a time. Balance cost vs. amount of use.
Bun in NC
07-30-2006 16:40:39
I bought a new Stihl 028 wood boss about 25 years ago - still works great!
Dug
07-30-2006 12:16:02
I bought a Stihl Farmboss last year and it is alright, but my 5 year old Poulan Pro starts easier and cuts nearly as good with a sharp chain. If I had it to do over, I would probably just keep using the Poulan till it died, then buy another. Of course, I won't cut much more than 1 cord per year.
rottenrobert
07-30-2006 11:40:24
Yup Yup Yup!!! here we go again.
Joe-Bob/IN
07-30-2006 08:08:30
Stihl or Huskie! Maybe one of those imported units but I have never seen a dealer for them so that would be a big no no.
MR
07-30-2006 07:53:49
Dolmar PS-540
Makita DCS540
I got the Makita off e-bay [blue Dolmar]
Bret4207
07-30-2006 05:12:12
Was in the saw business for years. Buy a Husky, Stihl, Jonsered, Dolmar, whatever your local dealer supports. Theres lots of good saws out there. A used Husky 266 would be my first choice.
tcwinkc
07-29-2006 22:19:59
I personally like the Echoes. They generally have an advantage with price, weight and displacement over most other manufacturers. Stihl was perty good years ago, quality has dropped off a lot in recent years. Many dont realize that Poulan and Husqvarna small frame saws are the same, not sure who manufacturers just look at a model 2150, they are a decent saw
Roy Suomi
07-29-2006 21:17:13
If I had to replace my old Homelite , I'd get a Stihl...29 years ago I bought a new Homelite 925. Heavy , hard starting , loud...But man can that saw cut...
Leland
07-29-2006 20:20:41
I bought a John deere saw about 6 years ago don't know who made it for them large motor 16" bar cuts what ever I sink it into and the saw cost me under 300.00 and have not had problem 1 with it so far .
Dachshund
07-29-2006 20:00:41
I have both a Stihl 290 and a Husqvarna Rancher 55. The Stihl is heavier and dosen't start or run as good as the Husky. The Stihl has WAY better bars and chain. Husqvarna "Customer Service" down right SUCKS. Stihl has better service network. Go with the Stihl.
Joe In MN
07-30-2006 08:36:03
 Re: What chainsaw to buy? in reply to Dachshund, 07-29-2006 20:00:41
I'M WITH YOU ALL THE WAY ! ! !
rodgernbama
07-29-2006 19:34:14
I would get either a sthil or husqvarna. Either would be good.
Big Mike
07-29-2006 19:10:14
Stihl is Great! Have a Farm Boss myself. I had a Poulan Made Craftsman that ran GREAT, but then the oiler went out on it!
joshn
07-29-2006 18:56:12
We have three Stihl farmbosses (029"s) in our family and all have been great saws. I have had mine for 7 years with a 20 inch bar and never had a problem with it, a little pricey but worth it!! I would probably go with a smaller bar unless you are taking down large trees.
Josh
blg
07-29-2006 18:40:21
husky got a 266 and 268 years back these saws will cut for you and your great grand children.put it in your will.there that good.
Tim B from MA
07-31-2006 09:05:32
 Re: What chainsaw to buy? in reply to blg, 07-29-2006 18:40:21
I have a 266 I bought in 1983, have cut hundreds of cords with it, and I can reasonably expect it is the only saw I'll ever need (knock on wood!).
youngfart
07-29-2006 18:13:44
I have two, craftmans, 18'' bars $125 each lasted five winters cuts 35 cord a year, price of one of those other saws, I can buy 8 of mine for the price thats a lot of wood and money saved in my eyes, because the new stuff is junk, had a husi, no good, blow up only a short time after owning it $900 saw, junk!!!!! !1
Don LC
07-29-2006 17:22:56
STIHL
JAY IN KY
07-29-2006 18:03:38
 Re: What chainsaw to buy? in reply to Don LC, 07-29-2006 17:22:56
again, STIHL, but about $350, but well worth it.
Mike in MI
07-29-2006 17:10:39
Kent,
I always had very good luck with Stihl saws. I have 028 - 034 - 010. Mike
Matt from CT
07-29-2006 16:59:20
Stihl.
I have a Stihl 039 (now a MS390) with a 20", probably overkill for you and over the price range. I fell upwards of 10-12 trees some years as I slowly clear the property. Figured it would be a 30 year saw for me, and I'm 8 years into that now.
I am worried one of these days I'll be in the local Stihl dealer getting a chain or somethin' and walk out with a Farm Boss as a backup saw...although a funny thing happened as I got older and smarter, it's been years since I've pinched a saw.
It's an MS290 in their new naming scheme. It's gonna probably be a tad over your $300...but IMHO well worth it.
Neighbor behind me runs a part-time cord wood business...runs a 440 Magnum. Helped him cut up a storm-felled tree between our property a couple weeks ago...drool...
ric1
07-29-2006 16:49:55
in 1985 ibought a 028 stihl 1 year old 18in bar and also a husquvarna 61 with a 20in bar i had them both for 20 years and i cant even imagine how many pickup loads of firewood not counting about 20000 to 30000 locust fence post my bother/dad and i cut over the 20 years i had them i couldnt honestly say one was better than the other but ill say one thing they will cut an cut without next to any problems at all so if you want a chain saw you dont spend more time working on it than cutting it dont get any better than these 2 saws i never had a jonsered but i hear from alot of people they rate right with these 2 saws.dont let the price scare you away because they are by far worth the extra dollars than the rest good luck
thejdman01
07-29-2006 18:28:46
 Re: What chainsaw to buy? in reply to ric1, 07-29-2006 16:49:55
Jonsered is my vote. Some auction deals can be found.
Ryan - WI
07-29-2006 16:21:39
Jonsered still makes decent saws too.
Midwest redneck
07-29-2006 16:09:12
The only chainsaws worth owning are the Stihl and Huskvarna. I have a Stihl 029 farmboss, with an 18" bar, runs great. I have cut lots of hardwood trees with it, get a spare chain too for what you buy.
GregC
07-29-2006 16:03:04
I"ve always had good luck with Stihl and Husquavarna.
mjbrown
07-29-2006 18:01:02
 Re: What chainsaw to buy? in reply to GregC, 07-29-2006 16:03:04
I have a thirty year old Farm Boss that is a great saw, as good today as it was when I was young. My cousin is a professional logger and uses Huskys. He cut himself out from under a log one time with one.
