Tool Talk Discussion Forum
Welding Rectifier Capacitor
Jimlll
07-29-2006 10:43:12
I inherited an old SMITHS ac welder and some diodes. I am making a rectifier and have been told that I need a capacitor downstream of the rectifier. What capacity should the capacitor be?
Jimlll
07-30-2006 16:25:19
 Re: Welding Rectifier Capacitor in reply to Jimlll, 07-29-2006 10:43:12
Thanks for your help, I will investigate each reply.
You guys can"t be beat.
MarkB_MI
07-29-2006 19:47:11
The general rule of thumb with filter capacitors for DC power supplies is to use the biggest capacitor that will fit into the space available. It is possible to have too much capacitance, but that's not likely in a welder.
Note that capacitors all have a voltage rating. Your should pick a capacitor rated at about double the maximum output voltage of the transformer. 75 to 150 VDC should work.
Note also that big capacitors are often of the "electrolytic" type. These must be connected in the proper polarity, otherwise they'll 'splode.
I would try it without a capacitor first. Capacitors are prone to failure, better to keep it simple.
Bob
07-30-2006 23:36:55
 Re: Welding Rectifier Capacitor in reply to MarkB_MI, 07-29-2006 19:47:11
He would want to use OIL-FILLED capacitors, NOT 'lytics.
And, look for caps labeled "No PCB's".
Hermit
07-29-2006 17:21:44
I went to some welding websites like Miller and Lincoln and found their owner's manuals section. They have manuals with wiring diagrams showing the capacitors and size. It appears to vary depending on the amperage of the machine. You might want to visit several sites and try to find a machine with similar ratings as yours and find the capacitor size that way.
Bob
07-29-2006 11:14:27
third party image
The link below doesn't exactly answer your question, but covers a lot of good points about making a welder rectifier.
