Tool Talk Discussion Forum
automobile electrical problem
mark from the f
07-24-2006 18:23:00
I have a '93 Chevy Suburban. It is the Starcraft conversion which means, "a buunch of electrical crap that causes problems." It has been drivin weekly for the past year with no problem. BUT, now that it sits in my polebarn for weeks at a time--the battery is drained. And I mean drained.
It has a second stereo on the back that wasn't working and just flashed 12:00 all the time. I thought this was the problem and pulled the fuse.
My question is this: is it possible to charge the battery, check the voltage (unhooked) then somehow put volt meter between positive post and chassis and get a negative reading?? Indicating a draw/drain somewhere? I thought I could start yanking fuses at the panel until negative draw was gone and readout read "o" or whatever battery condition is. Am I way out in left field. or is there a better way to see what is going on. The battery is only a year old. I think it is bad and drains by itself....while using truck, alt. and battery where perfect. Any help is appreciated. Mark
souNdguy
07-25-2006 08:38:16
 Re: automobile electrical problem in reply to mark from the fort, 07-24-2006 18:23:00
You must put the vom on an amp reading.. then put it inline with the battery cable to show current draw. Then start pulling fuses.
When this sort of thing happened on my 2000 yukon ( more electrical crap from GM.. ).. It turned out i had a burned up control panel for the AC.. believe it or not. i didn't think any of that was powered when the vehicle was off.. but apparently it was.
134$ part and 2 hrs labore to replace. Tech said that GM had 7 different control panels for the suburban and yukon ac units.. said they go thru them and have lots of problems... NICE!
Soundguy
MartyInVa
07-25-2006 08:15:21
I have a 93 F350 dually that was doing the same thing. It was the alternator.
Alternator has to have current to start charging. As it was explained to me there is a diode in the alt. that will go bad. When you shut off the engine it is supposed to stop the current flow to alt. so when they bite the dust the alt will drain the battery.
I'd check this before tearing the vehicle apart looking for a short or bad ground.
Hope this helps, Marty
KEB
07-24-2006 19:07:34
Hi, a lot of things like stereo's have "keep alive" circuits that are hot all the time (not switched with the ignition) to run things like clocks & keep the memory alive so you don't have to reprogram the stations every time you turn it on. I wouldn't think just a stereo would draw enough current to drain a good battery in a week, but maybe there's something else drawing it down as well.
You need to measure current (amps) not voltage. A multimeter should have an amps position which will measure current through the meter. Disconnect the battery negative terminal (current is the same in both positive and negative terminals), put the negative meter lead to the negative battery terminal and the positive lead to the cable connected to the chassis, and see how much current is being drawn. Then you can start pulling fuses or disconnecting stuff to see where the problem is.
Quick & dirty solution - install one of these knife switch battery disconnects you can get at the auto parts chains, & just disconnect the battery when the truck is sitting.
Good luck,
Keith
Buzzman72
07-24-2006 21:18:51
 Re: automobile electrical problem in reply to KEB, 07-24-2006 19:07:34
Absolutely correct. Checking between the post and the terminal for voltage will show you how many volts are being drawn, but it's not the voltage that kills the battery so quickly, it's the amperage.
And here's a tip to save you time with your multimeter: go to Wal-Mart and pick up an inline blade fuse holder and a package of 10-amp blade fuses, and install them on the black lead of your multimeter [solder and heat shrink recommended]. Multimeters tend to have a 10-amp fuse buried somewhere inside, and it's a lot quicker to swap out the fuse in your lead than to take the back off the multimeter and play seek-and-find with a glass fuse--which you probably don't have any of, lying around the shop. Learned that one from the automotive electrical course at the local vocational school...they have tons of blade fuses, but glass ones are rare there.
Remember...sometimes electrical problems are a bear to trace down. That's why auto electrical shops charge by the clock hour, instead of flat rate. If it takes them 10 hours to find a short, they bill you for 10 hours. [OUCH--extreme example]
Mark - IN.
07-24-2006 21:05:42
Pretty much hit the nail right on the head.
I remember years ago when was building boats, I made the mistake of using a wrong sized ground wire for...? I don't recall now, but found it by accident. Shut the shop down for the day and turned off the lights then noticed a glow from inside the boat. Hmm? Must've left something on, so went back to check. The dashboard was glowing faintly because whatever it was that wasn't grounded correctly was back feeding through the much smaller ground for the dash lights, illuminating the dash lights faintly when the ignition was off. A bad ground will certainly kill a battery over a period of time, obviously. And an ammeter would've found it if I hadn't known where to look for the mistake I'd made.
Mark
