Tool Talk Discussion Forum
Vehicle Speed Sensor
XRogerX
07-24-2006 18:04:43
I am having a problem with my new (to me) car. It is a 1999 Mercury Sable, with a 3.0l Vulcan OHV engine and 4speed OD transmission. I was out driving when I noticed my speedo had quit. The car also has a habit of holding on to 1st gear too long (like up to 3000+rpm at light throttle loads). The speedo mysteriously rectfied itself and shifting returned to normal. From my cursory internet investigation, it seem I may need a vehicle speed sensor. As the car has a 30 day 50/50 warranty from the dealer, I would like to approach them with some idea of what I think might be wrong before they tally up a big bill going down a dead end. Otherwise, I really like the car, as it is quite an improvement over the old 87 Mustang that decided to die on me a few months ago. It has only 50,000 miles on it, and no rust. I hope my run of good luck with Ford vehicles isn't about to end.
old_bc
07-24-2006 21:24:13
 Re: Vehicle Speed Sensor in reply to XRogerX, 07-24-2006 18:04:43
I have a 2002 Chevy Blazer 4 X 4 that had a bad speed sensor. It affected the speedometer, antilock brakes and the transmission would not shift into overdrive. old_bc
T_Bone
07-24-2006 19:30:58
Hi Roger,
The first thing I do on any puter controlled device on a glitch is to reset the puter. On auto's, disconnect the battery(s) over night as this resets the puter to the default program and clears the codes.
If it's truly a problem it will quickly show back up and throw another code.
T_Bone
bo
07-24-2006 19:14:06
It's the transmission input sensor. Cost around $20 and is located in the transmission...screws into the transmission. Has a plug in set of wires going to it. You unplug the wires, get a socket ...1" I think and screw it out and then screw the new one in. There will be another sensor near it and that's the output sensor,,same deal except that it makes the transmission shift like a truck with a bad clutch, both up and down.
I think...if you follow the transmission cooling lines to the transmission, both should be located about there.
I may have them reversed...but I'm correct. If your speedo is reading 0 and you're in limp home mode, then it's one of the sensors.
Hobo,NC
07-25-2006 05:05:08
 Re: Vehicle Speed Sensor in reply to bo, 07-24-2006 19:14:06
That would be good info if he were working on a chrysler product, Ford is different.
RandyBee
07-24-2006 19:07:20
Have them do a code check. If there is a PO500 code then have them change the VSS. Sensor is located on the transmission.
XRogerX
07-24-2006 19:39:11
 Re: Vehicle Speed Sensor in reply to RandyBee, 07-24-2006 19:07:20
Thanks a lot for the quick replies guys. I have a small OBDII code reader, will that do? I read one post about an EECIV reader. Hopefully, it's a quick and easy cure. Things are starting off kinda rocky with this car, but I'm keeping the faith for now.
RandyBee
07-24-2006 19:47:07
 Re: Vehicle Speed Sensor in reply to XRogerX, 07-24-2006 19:39:11
Yea the 99 will be OBDII
Hobo,NC
07-24-2006 18:12:12
Sounds like the VSS izz yer problem, the speed o meter also has problems also but will not affect shift points for the trans, the trans needs a good VSS signal.
RJ-AZ
07-24-2006 18:09:07
That VSS is a royal PITA to get to and change out.
If you are good a working by feel and in the dark you may get it. Since they generally start as an intermittent problem it may bee hard to get the dealer to fix it until it's a hard failure. But that malfuntioning VSS will throw your shift point all over.
