Tool Talk Discussion Forum
Found I-R compressor, and others.
jerrycpp
07-22-2006 18:48:21
Thank you all for your replies. I-R is sold by Northern, free shipping, BUT, you need a "start up kit." DeVair is the NEW name for I-R, and they are made in Canada. Gardner Denver is many $$. The best price per delivered CFM is Grizzly's Campbell Hausfeld. Anyone had one of them? I'm leaning strongly that way - 100% duty cycle, and the most CFM of all. Any and all replies most appreciated.
George in Biloxi
07-24-2006 07:59:01
 Re: Found I-R compressor, and others. in reply to jerrycpp, 07-22-2006 18:48:21
Hi,
Someone on here posted a compressor company call Eaton. I went ahead and spent the money on the 7.5HP 80 gallon upright. This thing is a beast and although $$. You can not beat the quality and price. They are built the old fashion way. They will paint it whatever color you want too.
George
http://www.eatoncompressor.com/page/page/504413.htm
Sorry for the late respon
07-24-2006 07:05:32
We've been running a 5hp 80gal Campbell-Hausfield compressor at our carwash for 16 years with no problems. ....It was purchased from TIP (TP) in Ohio, who previously sold C-H.
This unit has a cast-iron pump, and I wouldn't consider buying a compressor with an aluminum pump. .....It also runs at a fairly slow speed, which adds to longevity and helps to keep the noise down.
Chris(WA)
07-23-2006 10:50:15
A trip to Bellingham and Grizzly is always worth the drive. They have more good quality, inexpensive tools than anywhere I have found in 25 years here in the northwest.
CANNONBALL
07-23-2006 04:34:18
do you have a tractor supply close to you... they beat the heck out of that northern price for same thing... look at tp tools
http://www.tptools.com/dept.asp?dept_id=40&dept_name=Air%20Compressors... have nice day may God bless the usa
jerrycpp (WA)
07-23-2006 10:10:14
 Re: Found I-R compressor, and others. in reply to CANNONBALL, 07-23-2006 04:34:18
TP has Quincy compressors - a brand I'd seriously consider if they were priced right. With frieght clear out here in the middle of nowhere, a Quincy is about $700 more that the C-H Grizzly sells. Plus, Grizzly is only 160 miles away - a nice drive and no freight. Thanks again for all the replies - I envy all of you with the many choices so close.
cannonball
07-23-2006 12:24:47
 Re: Found I-R compressor, and others. in reply to jerrycpp (WA), 07-23-2006 10:10:14
try looking at this on ebay 320008689011
jerrycpp
07-23-2006 10:02:14
There are no TSC stores in the Northwest. When I'm working in the midwest, south, or east, I always go to one. I've written to TSC requesting consideration of a store in our huge agricultural area, but the response was not positive.
cannonball
07-23-2006 04:53:45
try this
http://www.mytscstore.com/search.asp
Don L C
07-22-2006 23:41:06
What is a start up kit.....
jerrycpp
07-23-2006 10:00:04
 Re: Found I-R compressor, and others. in reply to Don L C, 07-22-2006 23:41:06
A startup kit contains the magnetic starter and a few other things that come standard on most other compressors. All in all, Northern with its "free shipping" and need for the kit, is several hundred dollars more than the others.
xRogerX
07-22-2006 19:10:43
DeVair and IR are two completely different companies. DeVair are made in Canada, and are the carryover of the DeVilbiss industrial cast-iron compressors. Probably a bit better than an IR dollar for dollar.
fzbcheve
07-22-2006 19:00:46
We have a campbell hausfeld V-4 on a 60 gallon tank. puts out 16.7 cfm at 90 psi. We run a 3/16 tip on the sand blaster and it will cycle. have this unit now for six years and it realy works fine.run it sometines for an hour at a time.we keep our line pressure at 90 psi.
