Tool Talk Discussion Forum
Zero-turn mowers, which are the best
Midwest redneck
07-22-2006 14:58:30
I see a lot of zero turn mowers, I see Cub Cadet, and others at Home depot and in papers. I would love to cut the grass cut time in half with one of these, I currently have a push mower and it takes me 1.5 hours or so I have about 10,000 sq. ft to cut. Which are the best, what do they cost?, what to stay away from? I think that a 16-18HP would work fine.
rrains
08-21-2006 07:35:35
 Re: Zero-turn mowers, which are the best in reply to Midwest redneck, 07-22-2006 14:58:30
we just got a used dixon ztr. and the difference that it has made in the mowing is a miracle. But you do not do that much mowing and a decent standard rider would do a good job. We bought ours used and it still cost us almost a thousand dollars. Plus the little parts that had to be put into it. But as i said it has been a miracle. before with a 46 in and a 38 in and a 36 in rider it took us about two hours a day for 5 days to get our mowing done. now with just the dixon it takes about 4.5 hours to get all of the mowing done. we mow about 2.5 acres. but the biggest plus for me is that i can mow without killing my back. but the biggest downfall has been all the extra junk (dust, Bugs Grass clippings) that get blown up in my face. But the choice is up to you and you have to decide the money you want to have invested and also think how much weed eating you do. With the dixon we do very little but with the other riders we had to weed eat around just about every tree.
JT
07-25-2006 15:45:36
You have several choices, depending on how much cash you wanna dump into one. Dixie Chopper makes a good little 34-44 inch machine, sells for 5500-6000.00. These are a heavy commercial machine. To get a good homeowner machine, look at an Ariens or Gravely 1534 15hp 34" deck, these are homeowner units, but they have a fabricated, welded deck, same deck they use on their commercial machines, not the stamped steel you will finds on other low priced amchines. The 1534 sells for about 2500.00 plus tax.
jack12345
07-24-2006 21:11:41
Last year I got a ferris zero turn and it a great time mach saves 50/60 % in time good heavy duty well built unit.Good manual researched and tested several but like the ride/springs of the Ferris-I have rough ground
john *.?-!.* cub owner
07-23-2006 19:47:41
due to a worn out rider and arithritus in my back and an artifical hip I am looking at A ferris with the independent suspension. Howerer, they don't come cheap. starting price is around 5900, and they go way up from there.
RickL
07-23-2006 16:00:52
I have had the dixon units, as I asssemble them also for a dealer. They nice units but for me No. If you have much of grade they are hard to handle till you really learn how to hold them on the hill. Watch also on the ones you look at see if the deck actyually sticks out much on the left side if not thet are horrible for trimminng cause the rear tires are in the road,also alot of the new models regardless of brand have the gas tanks abover the reasr wheel and when you try to trim yo knock off the gas caps. Me if I was buying a new unit it would be the JD 300 series ALL wheel steer tractor model. Thsi way hill not problem,youstill have a small turnin circle like for trimming and you can ue all kind of attachments and when I priced them last month they were actuall cheaper then alot of the hydro zero turn units. Or find you a used JD LX176 unit. They are very nice units and very dependable. Been running that for years now.
I Bleed Green
07-23-2006 15:02:43
Scag made in Mayville Wisconsin
thejdman01
07-23-2006 14:37:26
Not many attachment for some zero turn models if that is a problem for you. Some manufactures dont make alot of attachments and LAST I KNEW (may have changed) grasshopper only had a single stage thrower for their mowers which dont work well. Something else to consider.
TimS
07-23-2006 11:24:13
We had a Dixon cone drive model, it was a good little mower, you just have to keep the cone drive adjusted. We traded it in this spring on a used Gravely 20 hp 48 inch mower, it works great as well....
huntingreen
07-22-2006 20:15:08
I have used the Kubota, Exmark and Hustler. Hustler by far out does the other 2. I have a 24 HP Honda with a 60 inch cut Hustler. I was mowing with a JD 455 and there are still some places I have to use it due to the grade.
Matt from CT
07-22-2006 19:40:05
Ok, I *know* you don't want to walk...
I'd still suggest you look at a used commercial walk-behind.
Something that's no longer useful for a landscaper running it 40 hours a week, would still run for decades on 10,000 s.f.
I have a 40" Toro that is about 15 years old...bought new by a full-time lawn care guy, then by a smaller one, then by a real part-timer, then by me. I have 2 acres, lots of trees and other odd shapes. Without bagging, 1-1/2 hours. My conventional riding mower with a 42" deck IIRC took 4 hours.
Now I do live in a region (southern new england) that has lots of lawn guys now...on Craig's List I see them for sale regularly. Some pretty expensive, but running mowers pop up for under $1000 on a regular basis.
wgm
07-22-2006 19:00:07
Bought a Dixie Chopper this spring. 50" cut, 20 hp Kohler, model LT2000. I mow about 2 acres with lots of trees. Cut my mowing and trimming time from about 3 1/2 hrs to about 1 1/2 hrs.
DelMN
07-22-2006 18:59:06
Kubota is the best! The rest can line up to see who is #2! But the Kubota will cost you. $6K for the gasser. Exmark is also excellent. Now made by Toro.
jerrycpp
07-22-2006 18:44:41
I bought a used Walker at auction a few years ago. It is a fantastic mower, and has a built-in pickup blower and container to hold it in. Expensive? Yes! But worth every penny.
Hobo,NC
07-22-2006 18:36:55
48� deck izz plenty Big, once you git over 48� they do not have as smooth a look�in cut. I mow 4 ac with a gravely 260Z 60� cut but do the trim werk and down the drive with a cub cadet 48� cut. Mt lawn izz not level its either up or down and all around. �bout 1/3 izz a bottom low area and the gravely izz to heavy fer it if we git wet times. The 48� cut gravely home owners will serve your needs and you will have brag�in rites to a ZTM. One thing thow if I had it to do over I would have got a Toro. I got a demo and used it to mow one time and it did a better job than the gravely, problem wuz I could not git�em to come down on the price so I walked away. I have had a few problems with the gravely and all of�em were parts that were used that were just good enough to git it out of warranty (mower deck pulleys) or that�s what they planed on. The replacements were good ones and I spec will give good service. Its hard to say what�s best, you are a big boy with money so git�ya one.
Gene-WI
07-22-2006 17:51:50
Just keep pushing, it's healthier for you and it costs less.
Midwest redneck
07-22-2006 18:05:48
 Re: Zero-turn mowers, which are the best in reply to Gene-WI, 07-22-2006 17:51:50
Well I am on my feet 55 hours per week on average being a machinist and what I dont need is more walking time, every morning when I get up and put my feet on the floor is it very painful for those first few steps. A rider mower or a zeroturn would be a life (foot) saver.
720Deere
07-24-2006 09:49:11
 Re: Zero-turn mowers, which are the best in reply to Midwest redneck, 07-22-2006 18:05:48
There is no way I would spend the money for a zero turn to mow less than 1/4 of an acre. A 48" to 54" walk behind would cover that area in about 15 to 20 minutes max. My yard is just under an acre (40,000 sf) and I can mow it with a Scag 54" walk behind in 35 to 40 minutes.
If you really don't want to walk for 15 minutes, you can get a velky to ride behind the mower. You'll still be standing, but you won't have to walk. The walk behinds are much much cheaper than a zero turn also.
Gene-WI
07-23-2006 06:29:48
Yeah I know what you mean about being on the feet all day. My brother-inlaw has a Grasshopper zero turn that he swears by, says it cut his cutting time by 1-1/2 hrs, traded his newer JD garden tractor in on it. It tips up for easy cleaning and for storage in the garage, he's also got a snowblower that goes on it for winter. He's had it for over 5 years and no problems yet... spendy tho. Gene
thejdman01
07-22-2006 17:30:51
I know very overkill for you probably, but if you can spend the money or scrape the moneyu together get a jd 935, jd f1145 etc. They are front mount zero turn mowers. I have never really seen the point of a zero turn (besides zero turn for manuverability. However I have a 455 and a 495 john deere lawn mowers all wheel steer and turn plenty short and w/power steering and hydrostatic on the foot feet can manuver them effortlessly. If you dont have alot of trees an all wheel steer 455 might be your ticket very very durable and turns very short. If you really want something manuverable because you have a bunch of obstacles trees etc get a zero turn front mount to trim under trees. I recommend getting the jd commercial models and they will last you many many years. A brand new cub will probably cost you 6000 or so a 935 w/500 hours may cost 8000 dollars but the jd will last you soooo much longer. Really look into a diesel, those little 3 or 4 cylinder diesels are so fuel efficint I mow 14 acres or so per week and used to have dixons, grasshoper etc simplicity "commercial model" (so lightweight and literally broke down every time out). they were all gas kohlers and would use 10 gallons of gas per week the little diesels use so much less. The dixon was horrible used a cone drive system which had to be bench adjusted (hvery lengthy process had to have special stand and tools.). New dixons hydrostatic are better they say, the grasshopper ok but not overly built and the simplicity is horrible. Now i have a F1145 a 455 and a 495 and they are all commercial duty very heavy duty and perform flawlessly. the f1145 is a 92 with 8000 hours on it and works flawless and it is shaft drives whien you hit stonest etc. Speaking of stones, jd blads wear super well, I am not the best about picking up sticks etc and jd blades take alot of abuse w/o getting knicks ripped otu of them and arent overly priced, more then i can say for others.
Rauville
07-22-2006 17:23:09
I bought a new Simplicity 52", 23hp ZTR. A real cutting machine that took about 1/2 the time off our lawn compared to our 55", 20hp lawn tractor.
The Wife will fight to run it. But then, she claimed the Bobcat also when we first got one.
The one problem with the Simplicity are the "tamper-proof" fasteners used on certain parts. I asked a question regarding that here a couple of weeks ago....and NO, I still have not found the proper tool.
CNKS
07-22-2006 16:40:02
You only need a zero turn if you have a lot of trees and/or a lot of other manuvering to do. Otherwise the JD and Cub Cadets Home Depot, etc sells are fine. Also remember that you get what you pay for. I consider the lawn tractors such as the ones Walmart and Sears sells to be "Throwaways", ie they won't last. Buy at least a mid-price product. Buy a good one and you will have it 20-30 years from now. 10000 sq ft is not much. I have 30000 and about 100 trees to mow around. I have a JD 525 front mount mower, not a true zero turn but close. I can mow the yard in an hour, another hour or 1.5 hours for the trees depending on whether I do them all. Cost $5300 in 1996.
Bud in NC
07-22-2006 16:35:49
SWMBO needed an new mower last week - it's her SELF appointed job. She loves to cut grass.....and I love to let her!!!
We checked with the hardware store down the road. They & their parents are kinda neighbors - never see them except for the store but they live with in 3/4 mile to us.
We looked at the ZTR mowers first. The the guy explained that they are fast and they handle like "Bobcat" or a Skidsteer. That was the first red flag to my boss. Trust me - my boss lady don't want nuthin' that handles like that! I have to re-train her on how to use the Yamaha "TerraPro" every Spring! What really scares me is that this is a lady who drove an 18 wheeler with her ex - NY to Cal & NY to Fl!
The BIGGEST thing that made us by the convential riding mower is that he explained that the ZTR mower steering "pushes" downhill. The front wheels are on spindles so they go where they want to and follow the terrain - NOT a good situation for someone who's not REAL comfortable with handling something like a Skid Stear! We have some SERIOUS hills here at our place.
FYI - We checked at Lowe's, HD, etc and the local store a heavier mower for $300 less than a lighter mower at the big places - off the floor - no neighborhood discount! Be sure to check the local places! It's a Husky, too -
thejdman01
07-22-2006 17:36:11
 Re: Zero-turn mowers, which are the best in reply to Bud in NC, 07-22-2006 16:35:49
Husky is pretty underbuilt but very true about the front end going where it wants.
davpal
07-22-2006 16:19:14
Wow, if you only have 10,000 square feet of lawn a zero radius mower is a bit of overkill. I have a 52 inch toro z master commercial zrt mower with a 23 hp kohler and it is rated at about 3.5 acres an hour. I mow two acres in about 50 minutes. So at about 25 minutes per acre it would take approximately 6 minutes to mow your 1/4 acre lawn. Is that fast enough!? It will only cost you about $6200 out the door at your local toro dealer. Good luck with whatever one you buy, they are a lot of fun, as far as mowers go!
Midwest redneck
07-22-2006 16:41:10
 Re: Zero-turn mowers, which are the best in reply to davpal, 07-22-2006 16:19:14
The 10K sq. ft. is, the back, the front the side and the strip all the way down the drive, 700' or so. Trust me a rider mower or a zeroturn would still be 1/2 hour or so with all the turns around the house and the deck and going along the woods.
Midwest redneck
07-22-2006 16:41:02
Logan in SE Tex.
07-22-2006 15:30:30
I bought a 40" 15 HP Gravely last year and love it. I cut about 1 acre and went from a 42" Sears 15.5 hp regular mower and it cut my time in half. I bought the "homeowners" model not the "Commercial". Seems to be a well built machine but time will tell.
Now, this year my neighbor went and bought a Cub Cadet 40" from TSC and he has already admitted to me that mine is a better mower, he used mine a couple of times before he bought his, as his old mower had died. I can tell by looking tha my deck is thicker and mine has 3 blades to his 2. I was able to buy mine because of a special low interest promotion that local dealer was having, I sure do like my mower. HTH.
Easy1
07-22-2006 18:27:48
 Re: Zero-turn mowers, which are the best in reply to Logan in SE Tex., 07-22-2006 15:30:30
I bought a Gravely 48 in Zero turn last year. About $4,000.
Midwest redneck
07-22-2006 15:43:17
What did it cost ya, total price?
KEH
07-23-2006 14:07:22
 Re: Zero-turn mowers, which are the best in reply to Midwest redneck, 07-22-2006 15:43:17
I bought a Dixie Chopper 44 inch, love it. It is a commercial model, about 5K. A ZTR saves time due to being able to turn quick and short.
Like someone else said, check thickness of mower deck. Also commercial models of various makes have a hinged floor deck so you can get to the belts easily. You will probably never wear out a commercial model.
KEH
