Tool Talk Discussion Forum
New Shop
Joe in Ne
07-22-2006 12:40:25
I was wondering if anyone could tell me if there is someplace I can get ideas to setup the inside of my new shop. I allready have the building built but am waiting on concrete and wiring until I figure out where I want everything. The building itself is 48 ft wide by 88 ft long with 18 ft sidewalls. Thanks
Slowpoke
07-25-2006 01:10:45
 Re: New Shop in reply to Joe in Ne, 07-22-2006 12:40:25
Successful Farming, Nov. '04, Vol 102, #11. Shops shown are 128x66, 102x50, 72x51, 70x50. Ideas for cranes, pits, wash & welding areas, air, electric, etc. I think there is a special issue dealing just with shops, but I can't fine mine and don't know the date.... www.agriculture.com.
Joe in Ne
07-26-2006 17:18:14
 Re: New Shop in reply to Slowpoke, 07-25-2006 01:10:45
So Slowpoke can I just google this issue or what?
Slowpoke
07-28-2006 02:11:30
 Re: New Shop in reply to Joe in Ne, 07-26-2006 17:18:14
Online Shop Tour.... www.agriculture.com/insider. Go to Shop Center. They may not let you in if your not a subscriber. Never been there myself.
Joe in Ne
07-28-2006 05:58:01
 Re: New Shop in reply to Slowpoke, 07-28-2006 02:11:30
Hey Slowpoke. I tried that one the other day. It did let me in but didn't really give me any new info. I like the Stuff guys are actually using in there own shops. On those sites they say they did it this way or that, not (If I ever did this again I would----- .) That's the meat I like. Thanks
neblinc
07-24-2006 08:34:16
You are not able to see my homepage.mac.com site? It is working for me.
I am out toward the town of Raymond.
You can email me at randy @ qualigraphs.com
neblinc
07-24-2006 06:23:55
Lots of info on the site below. I am still working on my 40 x 50 shop.
You can see pics here.
Link
Joe in Ne
07-24-2006 08:17:21
 Re: New Shop in reply to neblinc, 07-24-2006 06:23:55
Randy the website was interesting. Can't seem to get your site though for the pictures. Maybe I could come by and check out your progress. I just live a few miles east of lincoln
Ol Chief
07-22-2006 23:07:38
My shop is only 30 X 50 so no comparison to yours.However I have lots of crank out windows which I like for the natural light.Almost all of the cabinets and or benches are on casters with brakes on two of the wheels.All permanent mounted cabinets or tool boards are mounted 18 " above the floor to allow easy cleaning ( sweep or hose down ). I had the good fortune to find and purchase two fine steel work benches.Half inch steel plate tops on three inch pipe legs.I had never seen anything like this design of bench.They are lozenge shape.Pointed at both ends,8 ft.in length and 4 ft at their widest point.It is hard to describe how and why these benches are so handy to work on.They were designed and built by an old tractor mechanic and shop foreman who turned orchard farmer.I also installed two 4"X 18'pipes set in concrete just inside the main doors.At 10 ft.off the floor I welded a stop collar of 5" pipe and then slid a 5 "X 6' piece of pipe down from the top to rest on the collar.It was necessary to weld on four strips of 1/4"x 1" steel to take up the space between the 4 " and 5" pipes.Then at the bottom of the 5 " pipe, attached by welding,an 8"by 12' I beam parallel to the floor.Then attached a gusset from the top of the 5 inch pipe to the bitter end of the I beam and added a trolly and chain fall.At the top of and between the two 4 inch pipes, added a 10 inch I beam with a sturdy padeye with a long drop chain block.This allows me to have a poor mans crane with a nice swing radius of almost 12 ft.If on occasion If I may have a heavy load I can add a stiff leg anywhere under and along the 12 foot I beam for added support.One thing that was overlooked was installation of one or more threaded sockets mounted in the concrete floor into which eye bolts can be temporarily installed to use with a tugger winch.I am sorry to have been so windy,but hope this may be of some help.
Joe in Ne
07-23-2006 11:49:24
 Re: New Shop in reply to Ol Chief , 07-22-2006 23:07:38
Ol chief- I like your ideas. I had thought of somekind of boom but had kind of forgotten it. Seems like a really good idea ! I also like the idea of installing some anchors in concrete to pull against. I wouldn't have thought of that
Midwest redneck
07-22-2006 13:04:40
That is a huge home shop. I dont know if money is an issue but 18' side walls will make it hard to drywall or any wall covering for that matter. Shelving? cabinets?, high up storage?
Joe in Ne
07-22-2006 13:47:28
 Re: New Shop in reply to Midwest redneck, 07-22-2006 13:04:40
I have heavy equipment and over the road trucks and need the height to work on them. Of course money is a concern but I figure it's going to cost me somewhere in neighborhood of 60,000 to finish inside to where I want it so I want it to be done right. I have idea of office and bathroom and loft for storage but need more Ideas on efficient layout. I am going to build driveover pit outside with open end to work under trucks and such. I was thinking more of benches welding area and wash area. Just ideas in general. I am going to use tin on ceiling and drywall, osb, tin combo on sides depending on location?
RickL
07-23-2006 07:17:22
 Re: New Shop in reply to Joe in Ne, 07-22-2006 13:47:28
Joe in Neb; I have a 54x75 shop an assemble equipment for machinery dealers also in it.All of my work benches are on wheels. The largest unit is a wagon looking style and it is realy heavy and works with vise on it with no problem. As long as it on cement floor you can push it around but otherwise that unit I pull around with th elawn tractor. All other tables are on casters also,only way to go in my eyes. As far as heat I use the radiant tube heaters and love them. Have a small low clearence unit in the office part. As far as loft storage what I did was built those in the corners of the building angling from the door to the wall,basicall what i am saying is when you drive a unit in you will always be at angle as you can't reall get in to the corner just naturall driving in. thats the same angle my lofts follow,really work nice. The othe is simply over my office area. ANOTHER MUST HAVE IS EXHAUST FANS. Ieven use old refrigerators for storge etc sand they are also on wheels. I also made rolling tables out of pallets.the only item in my shop that is not on wheels is the machine tools,drill press,bandsaw,etcbut they are on reworked pallets to thet can be moved with forklift if I need to quickly once in while. My welding table is nothing but set of tractor rim band duals layed down atop each other with i 3/4 inche scrap plate on top. I have a gratie in the center and a 55 gal barrel inside that contains all item. Two chains on unitlift it up wioth forkilift to empty barrel when need. Above it is exhaust hood and fan,hoods can be made really nice using old 60bushel hog feeder lid. Basically everything in my shope I made or modified or created out of items that normal are found at the dump. Old hand pallet jacks that wrere the cheap unts with throwaway cylinders on them make excellent caddies for something to roll around on. Thats waht my homeaid tool chest rolls around on. IAr system is plumbed along along one side of building,compressor is in office part adition with a seperate quite closet,this way i don't have to worry about freeze up in cold year swhen I don't have al rest of shop really warm. Have two 80 gasllon tanks t together,plus i remove the bottom drains On the tanks and hook airlie hose to them out of cabinet this allows drainage and thei is the hose that goe outside use, simple but boy it keeps the system dry thast way and get you another air outlet at the same time. The one big roll table may be for sale as I have way more now than I need. Back to the loft are all I used for saftey railing was some old cattle panels. simple light but yet won't let you asccidently step off,also have a swing gate so cam forklift heavy item up sometimes. You only want to use the loft area for occasional use stuff etc. Don't put you bolt cabinet up there. Let me know if can help you some more as thats just some of the highlights in mine.
Joe in Ne
07-23-2006 11:58:51
 Re: New Shop in reply to RickL, 07-23-2006 07:17:22
RickL- Some good info. I like the idea on panel for safty rails. Cheap and easy. Also that idea on airhose on bottom of compressor was great idea. (Your other ideas were good too). The welding hood was good Idea. I was reading something about puttin my exhaust fans below concrete and running the imputs up toward ceiling. Don't know if thats for noise or to keep more of the heat in. Don't see why a person couldn't run your other ducts in to the main exhaust.
RickL
07-23-2006 15:48:55
 Re: New Shop in reply to Joe in Ne, 07-23-2006 11:58:51
All I know is they work for me. If I was to build another weld table I would put the fans below table that way the fumes would be suck down away from you. )Down draft style). Forgot to say under the hog feeder lid also is a 4ft light and the tubing goes out the center over to the wall. Tubing is just 12 inch drainage pipe had left fro culvert project. All welding ido now is in my air power helment. Best investment ever made.
mjbrown
07-22-2006 17:33:00
My building is much smaller than yours (36'x60') but for your use you might want to put a door on each end to one side of the centerline so you can drive straight through and have the other half (or more) of the building for shop benches, machine tools welding area etc. I layed mine out that way and it works well. I have old Steelcase desks that I mount on large rubber caster wheels that I can roll over to where I want to work with tools inside a vise on one corner.
Joe in Ne
07-22-2006 21:45:26
 Re: New Shop in reply to mjbrown, 07-22-2006 17:33:00
Thats a good idea with the desk's on rollers. Heavy enough to hold some weight and stay on the floor with the vise. Could probably use for roll around welding table too! These are the ideas I wanted. Good to hear bout the (Gordon) radiant heat too. I have some with blowers now and while they aren't a lot of trouble I do have some problems now and again. Thanks guy's
Ken Crisman
07-22-2006 14:21:03
Man Joe , one think you'll never regret doing is having heat put in the concrete floors . If I could do it over , that's what I would do . Nothing like it . When I built my garage I had never heard of it .God Bless , Ken
Joe in Ne
07-22-2006 14:50:17
 Re: New Shop in reply to Ken Crisman, 07-22-2006 14:21:03
Ken I have checked in to this in past a little. It was the electric kind and expensive to put in and expensive to use. I know there are other kinds that are more reasonable but don't know anything about them. I was planning on putting up 3 propane radiant heater's and installing a propane forced air furnace with a/c for office bathroom. If I could hook a boiler system up with the one in office might work but again don't know anything about them.
jim in N.M.
07-22-2006 19:20:32
 Re: New Shop in reply to Joe in Ne, 07-22-2006 14:50:17
Joe, for heat look into "Gordon Ray" infrared ,you can buy them in almost any length you need.They heat objects in and on the floor,trucks,tractors,tools etc. what I like is theres no blowers or drafts. I've used them in three differant shops,nateral & propane gas.email me if you need more info. Jim in N M
