Butch, I cant say not being there, but its my guess youre correct. If it has a 4 pole outlet its likely two legs L1 & L2 (Black n Red) of 120 volts with respect to the Neutral (White),,,,, , and an Equipment Ground (Green/Bare). It would be easy to hang a test lamp or voltmeter on and see ifs thats so and, of course, there would be 240 volts Phase to Phase L1 and L2. If a load connected up to the gennys is straight 240 ONLY Neutral would not be used anyway, just the two hots L1 and L2 and the Equipment Ground. The Neutral is required for any 120 volt circuits PLUS a safery equipment ground ya know, thats a 3 wire circuit, 1 Hot, 1 Neutral, 1 Equipment Ground. If the receptacle has one oddball or round plug, thats likely the Equipment Ground. NOWWWWW W NOTE OF CAUTION: Im not sure I agree with your idea to over ride or replace any 20 amp protective device cuz of exceeding the ampacity of whats on the other (Feed) side and it could overheat or damage something !!!!! !!!!! !!!. 20 amps at 240 volts = 4800VA Sooooo ooooo oo if you try n pull more then that the generator may overheat and/or the windings or wires leading to that receptabe could be over taxed ya know !!!! ALSO that 5KW rating you mentioned may be a hyped up max or surge power rating NOT that the genny is rated for 5KW CONTINUOUS. WHATS THE POWER REQUIREMENTS OF THE WELDER???? You gotta know that to figure what size genny it takes to run it you know. If its not big enough Im afraid when you strike an arc the genny may poop out lol. Ifffff f the welder only has a 20 amp rated plug, then Id be inclined to think the genny with its 240 volt 20 amp plug might handle it BUTTTTT TT if thats a welder with a 50 amp plug I sure dont see the genny handling it and it could be damaged ESPECIALLY if you oversise its fuses/breakers OUCHHHHH HHHHH YOU GOTTA KNOW THE WELDERS INPUT POWER REQUIREMENTS before trying to serve it with any genny and then if the genny cant supply it and you start oversizing any of its protective devices YOU MAY FRY SOMETHING. The basics of what amperage rated plug the welder has is a good clue and like I said, Ifffff ff its a 20 amp your genny may work buttttt if it has a 50 amp plug, that pretty well tells you the genny isnt gonna cut the mustard. DO NOTTTTT TTT mess with the gennys own protection devices is my advice not being there and not knowing the welders power requirements. If the welder only requires 20 amps at 240 volts you may be okay then !!!!! !!! John T Retired Electrical Engineer
