Tool Talk Discussion Forum
Waterproof coating for deck over garage
Stan in Oly, WA
07-19-2006 12:43:17
I have a 250 sq ft deck over part of my garage. The deck is covered with some asphalt type material that looks like 30# rolled roofing with the smooth side up. The seams are lapped and sealed with black mastic which is no more sticky than the roofing, so all of it can be walked on. I don't know if it's more ugly than nasty or vice versa.
Every summer for the past few years I've covered the deck floor with that green indoor/outdoor carpet that starts out looking like the felt on a pool table and ends up looking like a nylon scrubbing pad which should have been thrown away weeks ago. I didn't do it this year because the deck has started leaking into the garage below and I thought I might be able to apply something which would be waterproof and attractive, too. I'd like to do it myself, but I'm not totally opposed to having it done if it's the kind of job where doing the first one teaches you how to get the next one right. Any information about this would be much appreciated.
Stan
fepo
07-20-2006 07:05:37
 Re: Waterproof coating for deck over garage in reply to Stan in Oly, WA, 07-19-2006 12:43:17
rubber membrane up here is the way to go nowadays. It should be applied by a professional with proper fire proof particle board underlayment usualy applied with hot tar and stuck to the roof, then an underlayment of smooth membrane is applied, with a top membrane with a sand coating that is a heat and stick type, no nails.
T_Bone
07-19-2006 21:56:44
Hi Stan,
A close family friend that was a roof inspector for 35yrs then spent the next 39yrs as a expert court whitness for roofing cases told me there's only one choice for a flat roof, tar & sheeting.
There's a top layer called "cap sheeting" ???, thats 36" wide roll about 1/8" thick fiber tar paper with very small sand on the surface. You hot tar mop the surface then roll out the cap sheet, mop again, then over lap the next sheet by 3". A tar kettle/mop/bucket can be rented. A three person job at the minimum, one on the kettle, one to mop, one to roll & cut.
There's also different types of tar for different climnates. This is for expansion and contraction of the tar so it won't crack and leak. Wrong tar and you'll get leaks very easy. You'll need to check with your local building supplier of tar products for which one they recomend for your area.
Careful as tar burns very bad. If you get tar on your skin the only thing you can do is suck it up and cry then wait until it cools then remove with Forumla 409 spray cleaner. If you wipe the tar before it cools it will do nothing but spread the burn to a larger area.
T_Bone
paul
07-20-2006 20:44:09
 Re: Waterproof coating for deck over garage in reply to T_Bone, 07-19-2006 21:56:44
How does that work? 'Here' it gets to 95-108 in summer with sun directly overhead, and in winter it gets to -20 to -35 with little sun.
Not sure how a different setup can work better in a different climate?
Just curious, I understand parts of Calif are pretty stable at 60-80 degrees, parts of the NE & NW are cool & stable, Florida & the SW is just _hot_ all the time so I can understand the deal for those locations.
Perhaps our MN climate is why flat roofs don't work well here, & the membrane is now the only way to go. Those mopped tar deals with seams never do work well.
--->Paul
T_Bone
07-21-2006 22:54:42
 Re: Waterproof coating for deck over garage in reply to paul, 07-20-2006 20:44:09
Hi Paul,
Well I can't answer that question. When I lived in Colorado I was asking Frank why we always installed metal decking/roofing during the dead of winter and four hours latter I had a pretty good idea about roofing in general, however we didn't get into what made the tar mix different.
I never jumped too far into the roofing part of construction as in our trade once the boys found out you liked it or was good at it, that's all you would do the rest of your carrer.
T_Bone
Glenn F.
07-19-2006 18:59:47
This doesn't solve your deck problem, but I would not own a flat roof. They are nothing but trouble. Even on commercial buildings it is agreed a pitched roof would be better, but is not usually feasible.
Glenn F.
Ga Jack
07-19-2006 17:58:00
google decks undercover
some one in your area may be an agent for this product. good luck, jackie
Satsop
07-19-2006 15:32:52
Stan A few years ago a product called Duro Deck (I beleave) Was being Installed in this area. You might check if it"s still around. The people that used it seemed to like it.
Jim
nballen
07-19-2006 15:18:54
Would it work to build a " real deck" over what Midwest Redneck mentioned? Thinking it would keep the foot traffic off the gravel/tar.
Something like redwood, trex, ect.
Nathaniel
Midwest redneck
07-19-2006 14:45:44
When I was the maint. eng. at my old place there were 3 types of roof coatings (all flat too) 1. rubber roof, with big round gravel over the rubber. (did not leak unless you pierced it) kinda like a big condom. 2. gravel/tar, not bad, but it leaks after a few years. 3. modified build up, rubber type roofing with a heavy reflective paint over it, this was okay. But every 2 years I had to have a guy come and put down the paint. Just my 2 cents here but if it was me I would tar the *rap out of it and then put down pea stone. Have fun.
Bill in NorthCentral PA
07-20-2006 03:46:18
 Re: Waterproof coating for deck over garage in reply to Midwest redneck, 07-19-2006 14:45:44
Around these parts, there is built-up tar roofs (kettle and mop type), there is rolled roofing, and then the most common on new or reroofs is rubber membrane. Two systems, basically: 1. Ballasted (the condom concept) only fastened at the perimeter) and adhered - essentially the same roof glued to the substrate (usually rigid insulation which is screwed down) and fastened around the edges.
The real way to do this, ignoring roof slope concerns is to not walk on your roofing. Build a deck system or what have you, but walking on roofing is next to criminal!
Anyhow, good luck. Let me know if you think I can help.
Bill
07-20-2006 03:45:47
Bill
