Tool Talk Discussion Forum
Screwdriver rack
Dark horse
07-16-2006 12:23:57
I am making a tool board, and have drilled and installed appropriate size dowells for combination wrenches, now need a good screwdriver holder. If I drill holes in an angle and attach it to the board, the screwdrivers will flop around, and if I use a magnetic strip, it will cause the screwdrivers to become magnetized. please advise of any ideas. THANKS
R yan - WI
07-17-2006 16:40:40
 Re: Screwdriver rack in reply to Dark horse, 07-16-2006 12:23:57
I would think that pewrforated steel tube would work well. You don;t even have to drill the holes.
TimV
07-16-2006 17:19:40
I just use a piece of 1" x 3" wood with holes drilled for the blades. Simple, but it does everything I need.
Vern-MI
07-16-2006 17:15:21
I use screw eyes. Now what are you using to hold the regular pliers?
WvaJim
07-16-2006 16:04:51
Use 2 peices of angle, one on top of the other, let the upright leg on the lower angle butt up against the upper piece and holes matching in both pieces.
tinyy
07-16-2006 12:47:49
Use a piece of 2x2 steel tube drill thru both sides?
Brian G. NY
07-18-2006 14:15:20
 Re: Screwdriver rack in reply to tinyy, 07-16-2006 12:47:49
Boy, I never thought of that; I've got some light 2" "square" tubing that would work really well. Thanks
