Tool Talk Discussion Forum
Wooden Gate Hinges ?
Lou
07-14-2006 10:39:39
Cant seem to locate them localy, the type I want go right through the post with a L shape on the gate side that the gate piece fits over. Any online sources for hinges . thanks Lou
Lloyd Llama
07-14-2006 18:58:38
 Re: Wooden Gate Hinges ? in reply to Lou, 07-14-2006 10:39:39
Boss man gets mine at TSC.
JackT
07-14-2006 13:44:35
Surprised you can't find them locally. Very common item here but Colorado is ranch country. Just got back from Home Depot and they have them. Perhaps you could special order from your local HD? Ace and True Value also had them. Failing those, try www.hardwaresource.com What you are looking for is called a "bolt hook and strap hinge". A word of advice. Last spring I needed longer bolts so got some "cheap" chinese import ones at the local hardware store. They were too big in dia to fit my straps. Spent quite a while filing and cussin' em to fit. Get both your bolts and straps at the same place!
neblinc
07-14-2006 13:06:32
Any of these work?
Lou
07-14-2006 13:55:23
 Re: Wooden Gate Hinges ? in reply to neblinc, 07-14-2006 13:06:32
Randy, Thank You ive got them on the way.Lou
neblinc
07-14-2006 12:20:43
Are these what you are after?
Randy
Lou
07-14-2006 12:58:35
 Re: Wooden Gate Hinges ? in reply to neblinc, 07-14-2006 12:20:43
Hi Randy, No those are only for metal gates , they have straps that go around the gate pipe. Im mounting a wooden stockade fence gate onto a round post. Thanks for the try, Lou
