Tool Talk Discussion Forum
Pentagon Allen Wrench?
Rauville
07-10-2006 20:20:07
I've got a new mower that seems to be put together with 5 Sided (pentagon) "Allen" type screws and fasteners of different sizes.
I've checked with the local stores, and can't seem to find a set of wrenches / bits to fit. Do these type of fasteners go by a special name?
I realize progress has left me in the dust, but I've never ran into these before.
Thanks!
What Brand is the Mower
07-13-2006 06:21:49
 Re: Pentagon Allen Wrench? in reply to Rauville, 07-10-2006 20:20:07
What brand and model is this mower? I would take it back.
jeffcat
07-12-2006 19:24:07
Good golly I can sleep tight tonight knowing that the LAWERS are watching out for me so I will not hurt MYSELF!!!! Jeffcat
charles(mo)
07-12-2006 19:11:11
Rauville, I am not sure what kind of lawnmower you have, but the place you got it from ought to supply you with the proper tools.
I work for the electric coop in our area and we use a bolt that the head is 5 sided on our pad mount transformers. Code requires that the transformers have 2 locks on the cabinets, and that bolt counts as one of the locks. We have snap on nut drivers that fit it. I am not sure if anyone can get these though. But if Snap on has the sockets, they might have the allen wrenches too.
RandyBee
07-11-2006 17:47:52
third party image
Has it been determined that you have tamper proof Torx. I have had tamper proof Torx bits for years. Sk and others make them. I don't see the five sides.
RandyBee
07-11-2006 19:00:48
 Re: Pentagon Allen Wrench? in reply to RandyBee, 07-11-2006 17:47:52
Look at this site. Is this the one? If so it will cost money and a lot of paper work to get the tools.
jokers
07-20-2006 19:50:51
 Re: Pentagon Allen Wrench? in reply to RandyBee, 07-11-2006 19:00:48
Try this link for anyone who does need Torx Plus tools, they look pretty reasonable
Rauville
07-11-2006 20:07:29
No, I don't think that these are Torx fasteners. The bolt / screws are round headed with a recessed FIVE-SIDED drive. At first glance, you would think that a normal hexagon allen wrench / bit would work.
So far, the only thing I've found out is that BMW uses this style for some of their radio installations.
Thanks for your help.
Hal/WA
07-11-2006 17:34:30
And here I was expecting to read about a 1/4" Allen wrench that cost $8647 each and that the Army had 4 truckloads of them stored in climate controlled warehouses in Virginia since the Vietnam era!
Good luck--maybe you can have the dealer remove the odd sized fasteners and replace them with something you can work with. What a hassle! I would complain bitterly and threaten to sue unless they buy it back or make it possible to work on.
MarkB_MI
07-11-2006 16:01:02
Hmm, you may have grounds to get your money back. If the tamperproof fasteners are on components that you would reasonably expect to be serviceable, then I'd think that must violate some sort of anti-trust law. Remember that the Big Three were forced to publish their diagnostic codes because independent mechanics couldn't troubleshoot the undocumented codes.
What's the mower brand? What parts have the tamperproof fasteners?
Charles (in GA)
07-11-2006 06:47:41
Found this paragraph in an article online in a mechanical engineering magazine
" For the Torx Plus tamper-resistant design, maker Textron went with a plan for tight distribution of driver tools, according to Tim McGuire, director of application engineering for Textron Fastening Systems in the Americas. The drivers can be purchased only by original equipment manufacturers and authorized service personnel. The company also replaced the nominal six-point Torx Plus socket with a five-point design, since the Torx Plus sockets were designed to be removable by the original Torx bits when a correct Plus bit was unavailable. Naturally, any six-lobed Torx tamperproof bit would have been able to take out the tamperproof Plus screws if that design had not gone to five lobes, McGuire explained."
Rauville
07-11-2006 07:18:39
 Re: Pentagon Allen Wrench? in reply to Charles (in GA), 07-11-2006 06:47:41
Thank you Charles.
That's an interesting article that explains it. You buy a $7000 mower, and it's put together with tamper-proof fasteners! Forces you back to the dealer for as long as you own it.
Next step will be illegal wrench sets, sold in dark alleys.
Vern_MI
07-11-2006 09:23:21
 Re: Pentagon Allen Wrench? in reply to Rauville, 07-11-2006 07:18:39
Maybe they can come up with a tamper proof pitch as well so when you do finally grind or cut them out they won't even accept the standard treaded fasteners.
Stan in Oly, WA
07-11-2006 09:11:13
Hi Rauville,
I read the Tamperproof Fastener article, too, and agree that it is interesting. What I don't see is that putting tamperproof fasteners on an item which will be purchased for private ownership can be justified on the grounds of anti-vandalism, anti-theft, or anti-tampering with mandated settings such as on emissions controls devices.
Of course, any manufacturer can put their product together any way they please, and the consumer's recourse is to not buy it. The problem with this is that it isn't reasonable to expect a prospective purchaser of a single unit to examine the item down to the level of the number of sides in the head of each Torx style fastener.
I would talk to the seller about getting you a set of the appropriate fastener removal tools, and be ready to go right beyond them to the manufacturer, and right beyond customer service to the president of the company. Company executives are often unaware of what's happening at the user level. You don't have a lot of leverage in this, but you can mention that you will at least post the name and circumstances of the product on every YT forum and every other forum you visit. There's nothing illegal or libelous about stating in writing that you bought a certain brand/model product which is put together with fasteners for which removal tools are not currently available to the public. Potential purchasers can form their own conclusions about why.
All the best, Stan
Chris(WA)
07-10-2006 21:24:12
Great, just what we need another type drive for a fastener!! I would try the Snap-on website first. They will have the most selection and variety. I imagine Craftsman will have them soon as well. The only five sided allen I have ever seen (so far) is the drive for opening the valve on a fire hydrant. Who is the manufacturer of the mower? Sometime I think the engineers should be forced to work on every product for a year before they are allowed to release it on the public.
Rod (NH)
07-10-2006 20:55:19
I think you are talking about hex drivers. They come in both standard and metric for 3/8 and 1/2 sq drive tools - probably also 1/4 sq drive.
third party image
Rod (NH)
07-10-2006 21:02:38
 Re: Pentagon Allen Wrench? in reply to Rod (NH), 07-10-2006 20:55:19
OOPS! You did say five sided. I should have read your post more carefully.
504-1
07-10-2006 20:40:48
Look for Torx sockets, they come in 1/4,1/2 and 3/8 drive.
Matt from CT
07-11-2006 05:14:21
 Re: Pentagon Allen Wrench? in reply to 504-1, 07-10-2006 20:40:48
Torx are six-sided.
