Tool Talk Discussion Forum
buffing wheel question
brian 1
07-10-2006 16:32:40
Any hints on buffing black rubber marks off clearcoat? Dark maroon paintjob has some scuff marks from a rubber weatherstrip collision. Doesn't have to be perfect so I'll save the deductible and buy a buffer if that will work. Thanks.
GA JACK
07-11-2006 04:20:20
 Re: buffing wheel question in reply to brian 1, 07-10-2006 16:32:40
Try hand rubbing first with WD-40 and a clean cloth. Follow up with wax. May take some elbow.
good luck, jackie
CNKS
07-10-2006 17:10:52
Before you use the buffer, try hand rubbing it with some automotive rubbing compound -- I do not have a brand in mind. Just be careful that you don't scratch the clear. I hooked the plastic bumper on my 2005 GMC on my trailer tongue, while trying to back into my shop (not the trailer, just the pickup). I got all the black paint off, unfortunately the "collision" scratched it also. I touched it up, not really noticeable. If you have not used a buffer before, you can get into more trouble than you want. If you have actual scratches, you might have to, though. In that case you need a rotary not an orbital, as you need heat to get the scratches out.
brian 1
07-10-2006 18:52:53
 Re: buffing wheel question in reply to CNKS, 07-10-2006 17:10:52
Thanks for the help. Clear is scratched already but not too deep, it won't be perfect but body shop wanted almost $1000.
