Tool Talk Discussion Forum
Drilling or welding a hardened steel shaft
Gwiz
07-10-2006 15:28:46
I added a slip clutch in the driveline of by bushhog, so I cut 4+ inches off the 1 inch square shaft. Then when I tried to drill a new hole in the shaft, I realized it's hardened steel. I either need to drill a 3/8 in hole through the shaft to hold the yoke on the end, or weld the cast iron yoke to the shaft. What do I do?????
I have a wire feed welder, but have never welded cast. Thanks,
James
KeithF
07-12-2006 10:34:11
 Re: Drilling or welding a hardened steel shaft in reply to Gwiz, 07-10-2006 15:28:46
I have drilled holes in case hardened shafts before. Most are hard about an eighth inch or less from the surface. I used a Dremel tool stone to grind into the surface at the location where the hole would be. I then would take a small diameter high speed drill bit and try drilling a hole. If it was still too hard I would grind some more until it would start penetrating. This takes some patience, but it will work. It also requires sharpening the drill bits as they get dull and use a good coolant. Once a hole is drilled through it is easier to enlarge the hole to the correct size as it does not have to cut the center out.
Fred Martin
07-12-2006 08:37:00
The shaft is toughened up...it is not too hard or it would be brittle when something is hit with the mower, it would shatter. I would go to the local hardware store and get a masonary bit and use that. I wouldn"t get it too hot or it might melt the silver solder holding the carbide to the shank. Use a coolant or oil and probably not over 400 rpm for a 3/8" drill....and it is not advisable to use a masonary drill in a hand electric drill for drilling steel...use a drill press if you can. Fred OH
Gwiz
07-11-2006 16:31:42
I bought a cobalt bit today, and it took out a few spiral shavings, then stopped. I can't seem to get drilled in past the surface. It was the same on the other side, I took out a few shavings with a HSS bit, but when I get to where the whole bit it trying to cut, it stops. Seems to roll the cutting edge of the bit down. Thanks for your suggestions.
James
Nebraska Kirk
07-11-2006 12:13:48
You can weld the yoke to the shaft. The yoke is forged steel, not cast.
Joe(TX)
07-11-2006 05:33:59
Try heating the spot you want to drill until it is cherry red and the let it cool slowly. This works on casehardened shafts. Use a cobalt or carbide drill.
Ryan - WI
07-10-2006 20:26:44
Hindsight is 20/20 and all but wouldn't it have been better to pull the whole end out and cut the length of the end that didn't have the yolk on it?
Midwest redneck
07-10-2006 15:58:03
If the steel shaft can be filed then it is only semi-hard, like maybe 40Rc. 40Rc heattreated steel can be drilled into with High speed steel tooling. Use a center drill on a bridgeport and then low speed and feed for the drilled hole. Or use a carbide drill and carbide center drill.
Davis In SC
07-10-2006 19:07:56
 Re: Drilling or welding a hardened steel shaft in reply to Midwest redneck, 07-10-2006 15:58:03
It might just be Induction, or Case Hardened. If so, once you break through the hardened surface, drilling should be much easier.
