Tool Talk Discussion Forum
Taper Taps
DLM
07-08-2006 18:34:30
More imfo. on the taper taps. The cuting area of the tap is 4 in. long the small end is .230 & the large end is 7/16 or .437
there are 8 taps in this set all marked 7/16 with
threads rangeing from 18 through 32 overall lenght is 5 in. These were made by Wiley & Russell MFG. Co. late 20s or early 30s Thanks Don
Ted in NE
07-09-2006 19:11:05
 Re: Taper Taps in reply to DLM, 07-08-2006 18:34:30
Taper taps were used to repair cracks in engine blocks & other castings. Also had the tapered screws to go with them. Would drill & tap overlaplig the hole & plugs to stitch a crack. Worked well
Ralph - Ohio
07-09-2006 16:58:48
This is a situation where a picture would really be worth a thousand words!
Easy
07-09-2006 14:12:57
Are they progressive cutting, in that the 2nd diameter is cutting where a 1st diameter already cut?
DLM
07-09-2006 14:26:12
 Re: Taper Taps in reply to Easy, 07-09-2006 14:12:57
No they are a taper
