Tool Talk Discussion Forum
Surge brakes
JoeK
07-07-2006 16:22:57
Pros and Cons please. 7000 rated bumper pull trailer,occaisonal hauling,couple hundred mi radius.2 man/truck partnership on trailer.
Dan in Ore
07-11-2006 16:42:57
 Re: Surge brakes in reply to JoeK, 07-07-2006 16:22:57
I dumped a trailer with a tractor on it partly due to stupidity on my part and partly because of surge brakes. If I would have had electric brakes, I probably wouldn't have lost it. The main problem with surge brakes is that you can't apply the trailer brakes without applying the tow vehicles brakes.
souNdguy
07-08-2006 22:32:59
I'd sooner carry a chain and anchor than use surge brakes.
Soundguy
BFO
07-08-2006 10:36:16
Throw the surge coupler away, far away, they are dangerous. Put an electric over hydraulic actuator on the trailer and a compatible controller in each truck. This eliminates the problems that electric brakes are prone to from intermittant use like rusted drums and magnets, wiring shorts. Hydraulic brakes are much more positive.If this is not an option then go with electric. One of the biggest advantages over surge brakes is independant control of the trailer brakes from the cab of the truck.
KraigWY
07-08-2006 07:05:19
I was on the APD Bomb Squad before I retired in '94. Our bomb bucket was in a surplus Army 2 1/2 trailer. Difficult to stop. I made the mistake of having the Dept install surge brakes on the trailer. You can't back up the sucker. Especially in winter (Its been know to snow in Anchorage). I don't think I would ever go to surge brakes, they are dangerious.
Bret4207
07-08-2006 03:34:11
Although there are lots of surge rigs around, they aren"t legal in some states, like NY. Problem is they only work when you"re going forward and brake. If you are backing you have nothing, plus no breakaway system on most. Go electric.
Butch(OH)
07-07-2006 20:23:12
In Ohio they aint legal except on light boat trailers.
KEB
07-07-2006 19:16:17
I hate driving a trailer with surge brakes. The only semi-valid reason for them is to allow rental trailers to be towed with vehicles without electric brake controllers. You have a lot more control with electric brakes, plus as already pointed out you can manually apply electric brakes if needed.
If you already have a trailer with surge brakes, an electric over hydraulic setup would probably work. These use an electric controller to operate a hydraulic master cylinder on the trailer. I have no personal experience with these, and no info on what it would cost to convert a trailer, but just wanted to suggest another option that might be worth looking into.
Keith
mjbrown
07-08-2006 05:52:53
 Re: Surge brakes in reply to KEB, 07-07-2006 19:16:17
Also electric brakes have a break away switch that applies the breaks if the trailer comes unhooked from the tow vehicle.
Gerald J.
07-07-2006 17:29:46
Put on good electric brakes on all wheels and proper brake controllers with manual overrides in the trucks. We'll all be a bit safer.
Gerald J.
Tim Casbolt
07-07-2006 17:30:54
 Re: Surge brakes in reply to Gerald J., 07-07-2006 17:29:46
yea, like he said.
JoeK
07-08-2006 22:21:58
 Re: Surge brakes in reply to Tim Casbolt, 07-07-2006 17:30:54
Thanx for the input...we had pretty much settled on the trailer except for the brake options.Main reason we were even considering surge brakes was the ability to shuttle the empty trailer from pt-pt with a car/suv w/o brake hookup.Brakes are not req at all under 3000GVW here.Electric sounds like the way to go though on the full size trucks.
