Tool Talk Discussion Forum
Chevy Website For Towing Capacity
Glenn F.
07-05-2006 19:48:48
Is there a website where one can determine the towing capacity of an '88 Chevy 3/4 ton pickup?
Thanks, Glenn F.
Leland
07-08-2006 21:14:45
 Re: Chevy Website For Towing Capacity in reply to Glenn F., 07-05-2006 19:48:48
www.chevytruckworld.com
Joe (Wa)
07-06-2006 18:51:58
Probably more than you wanted to know.
Joe
CNKS
07-06-2006 09:34:37
The tag on the door gives overall GVW, and GVW front and rear, not towing capacity. Weak point in light duty is the rear axle.
buickanddeere
07-06-2006 13:21:38
 Re: Chevy Website For Towing Capacity in reply to CNKS, 07-06-2006 09:34:37
The lightweight 1/2 ton frame twists and makes alignment and handling a problem when overloaded. Then it will eventually bend and/or break. We have all seen pickups with the frame bent between the box and cab. The top lip of the box is almost touching the cab yet at the base of the cab there is a couple of inches of cab/box clearance. Overloading any equipment is just a fool who is going to waste $$$ and/or hurt/kill inocent bystanders or himself.
CNKS
07-06-2006 17:01:22
 Re: Chevy Website For Towing Capacity in reply to buickanddeere, 07-06-2006 13:21:38
That's what I call extreme abuse. I wouldn't even think about doing something like that. My point was most people don't use equalizing hitches, thus a slight overload, or maybe even with limits, repeatedly, the non-floating axle is going to give up. Half-tons or LD 3/4's are ok if they are used for the purpose for which they were designed.
buickanddeere
07-06-2006 17:35:35
 Re: Chevy Website For Towing Capacity in reply to CNKS, 07-06-2006 17:01:22
We have all seen them. Usually on the way home from a farm auction or antique show.
old
07-05-2006 21:16:17
Can't really say much but when I buy a truck, like my 1980 chev heavy half I rebuild it to pull/do what I want and don't worry about the tag on the door but I also do a lot to beef it up front to back.
CNKS
07-05-2006 20:01:21
I don't know of any, but if it is a light duty 3/4, not that much more than the half-ton, which is about 6500 with a 3.73 rear. Current 2500 HD's (gas) are rated at about 9500, I believe.
2x4
07-05-2006 23:07:18
 Re: Chevy Website For Towing Capacity in reply to CNKS, 07-05-2006 20:01:21
you are close. I think its 9800
504-1
07-05-2006 20:14:23
should be on a tag on the drivers door
