I'll put the generic FireWise link below -- many state forestry (fire) agencies have their own FireWise programs customized to local conditions. It's a good site on general maintenance & clearance items. I like the idea of a simple metal yard shed. Kept in an area it's mowed around so you don't have much if anything to burn around it. Also make sure you close off the bottom with chicken wire or lattice work or something similiar to keep dry leaves and pine needles from building up under the building. That's lost people several sheds in my town over the years when a simple grass fire or an ember from burning garbage spread to the nice dry fuel under the shed. In college when I worked for the State Parks, our flammables (even lubricating oil) where all bulk-stored in a seperate, masonry building about 100' from the nearest structure. But that, IMHO, is probably over-kill for the average homeowner. I guess if I'm a farmer or big time hobbyist buying fuel into 275 gallon tanks, and having 55 gallon drums of oil like the State did, it might make more sense! And make sure you locate it so it's downhill of buildings you care about -- so if a plastic gas / diesel / kerosene container melts, it doesn't make a flowing stream of gasoline across your driveway and into your garage :)
