Tool Talk Discussion Forum
Tanaka weedeater?
yak651
07-04-2006 07:13:36
I picked up a Tanaka TBC-501 at an auction. Cleaned up the carb, it"s getting spark, seems to have good compression, can"t get it to start. Anyone have any ideas?
Slowpoke
07-08-2006 18:20:13
 Re: Tanaka weedeater? in reply to yak651, 07-04-2006 07:13:36
Cracked/leaking gas line. Plugged filter. Replace it with model aircraft fuel line.
Ross
07-07-2006 19:53:56
I've got a Tanaka and I've run stihl, toro, homelite and the automatic head on the Tanaka is the best by far. Mine's a little older and doesn't have a primer bulb so it's a little cold blooded but once it starts it's been amazing and it gets used quite a lot.
Ross
JT in Illinois
07-07-2006 12:17:24
Could be low compression, nneds a minimum of 90# on 3rd pull, could be crankshaft seals, crankcase gasket, plugged exhaust, broken or cracked insulator between carb and block.
MikeCatthemuseum
07-04-2006 09:34:06
Take off the muffler and clean it out. I had one I was working on for a neighbor doing the same thing last year. It would hit once and nothing. I had about given up when I noticed the exhaust pipe was plugged solid by a dirt dobber. Stuck a screw driver in the exhaust pipe, shook out the dirt and it ran perfectly.
If that's the big Tanaka with a slide Mikuni carb, they are fantastic machines. I did yard work years ago with a guy who kept buying cheap Weedeater brand trimmers. They'd last about half a season. I finally convinced him to get a Tanaka and it was running three years later when I went on to better things.
Maark
07-04-2006 08:14:39
Even though it has spark, install a new plug. Sometimes a plug will show fire when grounded to the case but will not fire when under compression.
