Tool Talk Discussion Forum
Sideways fuel filter w/diesel update PLUS galvaniz
DAN9-Midwest
06-26-2006 16:27:35
My prior question dealt with using a Hydrosorb II waterblock and particulate fuel filter mounted siedways to make a portable tank fit into my pickup better. Could I do it?
Well, I called Cim-Tek (smart bunch I'll add) and got the skinny. They said you can mount a particulate filter sideways with little impact and to a lesser degree a particulate/waterblock filter CAN (but should not) be mounted sideways. It absorbs far less water that way so upright is the way to go. While I had them I asked about the eternal galvanized and diesel debate. They said for low usage, diesel and galvanized was no problem but for higher useage the dissimilar metals can cause a static discharge. They added that galvanized should never be used with Bio-Diesel because of major dissimilar metal problems and resultant "corrosion". Since I figure Bio might be in our collective future I went with black iron pipe for a connection and will mount the Hydrosorb filter the right way.
Charles (in GA)
06-27-2006 06:45:20
 Re: Sideways fuel filter w/diesel update PLUS galv in reply to DAN9-Midwest, 06-26-2006 16:27:35
This is good info for me as our homeowners association, which owns a M-F 165 for mowing and chipping and a SCAG for mowing also, plan on obtaining a couple of small fuel tanks and having the bulk dealer deliver to us.
I'm not so sure its a good thing, especially with the diesel since the usage is low, but at least I have ideas of where to go as far as the filter issue is concerned.
Charles
Don-Wi
06-30-2006 09:07:36
 Re: Sideways fuel filter w/diesel update PLUS galv in reply to Charles (in GA), 06-27-2006 06:45:20
I'd be more concerned with gas stored long term than I would be with deisel. I drained the last 15-20 gallons of fuel oil out of my grandma's tank in her basement that was there for probably a good 10 years. I drained it through the filter on the bottom of the tank and dumped it straight into the tractor with out any problems.
Donovan from Wisconsin
