Tool Talk Discussion Forum
Craftsman cordless drill - batter replacement
Chuck, WA
06-24-2006 11:26:24
A few years ago I bought an 18-V Craftsman cordless drill. When I plugged in the battery to recharge last week, both the red and green lights on the charger came on, and the note on the charger said that could mean either that the battery was failing, or that a "soft charge" was initiated.
Since I don't know what a soft charge is, and not wanting to be without a bettery, I went online looking for a battery. Sears doesn't even have a battery pack number that is close to what's on the battery, and the model number on the drill is conveniently on the plastic housing, on the side that is in contacat with anything it is layed down on. Naturally, that means it's worn off. The worklight that came with it uses the same battery, so that means I'll have at least one that is working, but it's model number is in the same 980... series as the battery, and it specifically says to not use any other battery.
I've gone out online to some of the battery houses and haven't found anything helpful.
Help! Any suggestions? This was an 18 volt 3/8" variable speed "special edition". The number on the battery is 982027-001.
Thanks!
Chuck, WA
PS...Based on the replacement batteries I did see in the Sears web page, can a replacement battery actually cost over half of the cost of the tool itself? Am I that out of touch with reality?
mtgummibear
06-29-2006 08:29:21
 Re: Craftsman cordless drill - batter replacement in reply to Chuck, WA, 06-24-2006 11:26:24
Before you give up on that battery entirely, let me tell you my experience with a craftsman.
If I am working the drill hard in hot weather it will not go onto fast charge if I bring it inside and put it on the charger immediately. In fact, it will never seem to charge to full strength.
But if I let the battery cool for 30 minutes or so before I put it on the charger, then it's fine. Goes to fast charge and charges back up.
I don't know if this has any connection to your situation, but thought I would let you know.
Larry
kidbob
06-25-2006 21:54:16
The battery supplier I use will replace all of the cells in the 18V pack for less than $50.00
phil lowe
06-25-2006 16:58:03
Chuck ,,repal,cements are at least 1/2 or better ,I've gotten power packs rebuilt at Battery place and the drill worked better then original ,,drill had more omph!!,,but yup it's pricey ..
oleblu
06-25-2006 16:45:12
Chuck, You might want to look at this site: www.batteryrebuilders.com I"ve never delt with them, don"t know them from Adam. Good luck. oleblu
J.C.H.
06-24-2006 21:48:51
Try Ryobi for a Battery or better yet pitch it and get a new drill. I have had Sears 18 volt and the Coleman that Checkers sells lasts as long and does not cost what the sears does. I exclusively use Ryobi's from Home Depot now. If it quits, throw it away and get another new one. we have 4 of thier 7.2 volt drill for instance around here and they cost around $25.00 Pretty good drills for not much cost.
Leland
06-24-2006 19:00:30
find a local battery store most of them can rebuild the power packs about as cheap as a new one .
amo
06-24-2006 14:28:15
try interstate batteries or call sears repair at 1-800-473-7247. trhey have different batteries than what the internet shows. good luck.
Chuck, WA
06-24-2006 14:44:23
 Re: Craftsman cordless drill - batter replacement in reply to amo, 06-24-2006 14:28:15
Amo...yeah, saw Interstate online, but they didn't have a catalog online and the closest to me is about 80 miles. I will try them though. Also, I will try Sears, but am so ticked off at them lately that I'm not sure I'll ever buy form them again. Big talk, huh! :)
Thanks!
Chuck, WA
Mike in Utah
06-24-2006 13:46:28
Chuck,
I can't say for sure if yours is like this but most cordless tool battery packs are just typical individual rechargeable batteries connected in series to obtain the required voltage. These are then put into a special case to fit the tool and allow the manufacturer to charge a fortune.
If the battery pack is dead, you might try opening it very carefully (so that it can be fastened back together) and see if you can get some replacements. You'll save a lot of money!
Chuck, WA
06-24-2006 14:46:25
 Re: Craftsman cordless drill - batter replacement in reply to Mike in Utah, 06-24-2006 13:46:28
Mike...Thanks! That's a good idea. In fact, was just out using it and noticed that it has screws holding it together. Worth taking a look when it actually dies.
I had it on charge, and this time, only the red light came on and it took a charge. Will see how it lasts.
Thanks again!
Chuck, WA
Chuck, WA
06-24-2006 11:41:00
Wow...that was quick!
Hay...yeah...I guess I knew that...just wanted to hear somebody else say it. :(
Jay...just made my first eBay buy and haven't received merchandise yet, so still a little gunshy, but will take a look.
Thanks, Both!
Chuck, WA
Stan in Oly, WA
06-24-2006 17:57:41
 Re: Craftsman cordless drill - batter replacement in reply to Chuck, WA, 06-24-2006 11:41:00
Hi Chuck,
I have been buying things on eBay since Nov '04, and my wife started buying things there about a year later. We have yet to have a bad experience with it. Very few problems and those have been simple mistakes, easily straightened out. I've met a number of good and interesting people through eBay (going to pick up items) and corresponded with several others. My wife even got me a Soviet Air Force watch from the Ukraine which I thought was a risky purchase, but it came off fine. I had an awful time getting an explanation of how to set the watch because it used a different method than any watch I'd ever seen, but the seller was finally able to explain it to me (his English was only marginally better than my Ukrainian.)
I don't think that eBay is the site it used to be (before I was using it, I mean.) It's getting to be less and less like an auction site, more and more like an online store. It's safer than it used to be, but less interesting in both good and bad ways. Paypal used to be worthless verging on criminal, but it's gotten quite reliable since eBay bought it. My guess is that it's only a matter of time until another site comes along to serve as the real auction place that eBay is letting slip away.
The place you WILL get scammed if you aren't on guard is the fake e-mail messages you'll get which purport to be from eBay, Paypal, and angry buyers who are going to report you to Ebay if you don't send them the widget they bought from you Right Now! Every week I get several bogus security alerts (not) from Paypal about why my account has been reduced to limited use status after several third parties have attempted to access it. I'm looking for a quick way to forward these alerts directly to that government minister in Nigeria who keeps offering me vast sums of money just to let him deposit his purloined funds in my bank account. What a world, huh?
All the best, Stan
Slowpoke
06-29-2006 01:36:01
 Re: Craftsman cordless drill - batter replacement in reply to Stan in Oly, WA, 06-24-2006 17:57:41
Well Stan, you said "PayPal used to be worthless and verging on criminal"....I see you haven't been to "Paypal Feedback and Suggestion Thread" lately. About 99% of the more than 500 entries are complaints and/or threats to sue because of PayPal freezing accounts, removing funds from accounts and other assorted bungles. I suggest anyone selling on ebay not use PayPal as a "Bank".
hay
06-24-2006 11:36:21
"battery can exceed half the cost of a new drill and battery"? yes, for sure. that's the cost of the convenience of a cordless tool. all the batteries for all the cordless tools i ever had were terribly expensive. sure don't seem right, though.
Jay87T
06-24-2006 11:34:22
yah might want to check out Ebay, I got all sorts of drill batteries there, and all running nice and strong.
Chuck, WA
06-24-2006 11:47:39
 Re: Craftsman cordless drill - batter replacement in reply to Jay87T, 06-24-2006 11:34:22
Jay...Nope...none on eBay...Thanks anyhow.
Chuck, WA
