Tool Talk Discussion Forum
Toilet Tank Sweats
Steve-Maine
06-24-2006 07:04:53
My new toilet tank sweats in humid weather. I tried putting a liner kit but didn't worked very good. Could I used spray foam insulation? This is what happens when you buy a cheap toilet at HD. My other toilet tanks came with built in liner and never had any problem. Thanks
JAY IN KY
06-27-2006 21:43:34
 Re: Toilet Tank Sweats in reply to Steve-Maine, 06-24-2006 07:04:53
looks like you have plenty of answers here but I will throw in my 2c anyway. I once had this problem in a house and as I recall it didnt matter much what time of year it was and I had city water. I drained the tank and let it dry out for a day then went out and bought some tompsons water sealer and coated the inside of the tank as well as I could,two coats. Never had a sweating problem again. Its cheap and easy to do. Dont know if it will solve your problem but it did for me.
Gravy
06-27-2006 12:58:51
Let 'er sweat! Just catch the drippings in a basin on the floor...
Dusy
06-25-2006 17:04:04
If you really want to spend some money and make it nice, put in central air. That will stop the sweating.
Dusty
Don L C
06-25-2006 08:52:23
Try hooking hot water line to it.....your only talking 3 gal.
J.C.H.
06-25-2006 06:10:40
Our House in n/c ILL. was plumbed entirely with Genova PVCP and PVC Pipeing and in the 25 years we owned it never did we have pipe sweat or tank condensation.My Mom had all Galvanized pipeing and everything sweated to some degree depending upon the humidity level.
J.C.H.
06-25-2006 06:24:58
 Re: Toilet Tank Sweats in reply to J.C.H., 06-25-2006 06:10:40
OOPS: Should have been "CPVC"
Bob
06-24-2006 22:31:08
Get a water tempering valve that admits some hot water along with the cold water, to bring the toilet tank fill water to room temperature, and it will no longer sweat.
Link
john *.?-!.* cub owner
06-24-2006 19:54:01
anychance you could set a tank someplace to run water lie to tank and then to comode? wouldn't have to be a hot water heater, jsut any tank to let water come to room temperature. Nother thing is get or amke a terry clothe cover for it.
Bernoulli
06-24-2006 16:40:11
My dad hated to wait for hot water so he had a hot water return line plumbed when he built his house. While he was at it, he had hot water plumbed to the toilets so they wouldn't sweat. I wasn't there to see the work, but any competant plumber ought to be able to clue you in.
Bus Driver
06-24-2006 10:26:53
You probably are using well water, which is cooler than the house temperature. City water in the Summer is often rather hot. If space permits, you could put a storage tank, not the bladder kind, in the line just before it goes to the commode. Run the incoming water in the bottom of the tank and the outgoing from the top. The water will have some time to adjust temperature. But the storage tank may sweat, may not be a problem in basement. Some mobile homes used to use plastic tank on the commode. I suppose for weight saving, maybe lower cost, less chance of breakage. The plastic would sweat less.
Lou
06-24-2006 10:25:20
I had this problem, but only a few days a year, bet you have a lot of girls around who flush ever time.
RayP(MI)
06-24-2006 09:59:05
Tank is sweating because refill water is substantially colder (below dew point) of the outside air. Years ago, my dad fixed his problem by putting a mixer valve in line, and bringing in some wrmer water from hot water line. Worked fine, untill tank refill valve failed, running a great deal of HOT water into tank. Melted wax ring at base of toilet! Insulation will help, but only to a degree. Have any way that you can arrange for room temperature water back to tank?
ron,ark
06-24-2006 08:28:17
You mean you have a toilet INSIDE the house? Whats this world coming to? I heard that some folks up-north were cooking outside on fancy charcoal thingys and pooping inside on porcelan pottys. :^) Seriously, we had that problem in a rent house once, and still have problems with the windows wanting to sweat and every now and then they wil start to mildew on the sills. Not much,It is probably because my wife keeps the house on a chilly 70-F even when the outside is 98F and the humidity is 79-85%
Mark - IN.
06-25-2006 05:38:35
 Re: Toilet Tank Sweats in reply to ron,ark, 06-24-2006 08:28:17
Haven't been to the Indy track in a couple few decades or so, but they used the biggest outhouses in the infield I ever saw. Troffs along the outside walls, one massive open stalled pooper down the middle with maybe 20 or 30 or more back-to-back holes cut out in plywood right down the middle over a massive pit. And that was the ladies outhouse. You know how us guys get when been drinking too much beer and don't want to wait in line when the troffs are full? You're sitting on the pooper trying to mind your own business, reading the newspaper or playboy, and up comes some drunk lady with a bad aim, and ruins your day as a spectator right then and there. Except for that, they had the Roll-Royce of poopers.
Mark
trw
06-24-2006 10:39:22
Believe it or not, we have a neighbor with an artesian well about 10 feet from the corner of his house and they do NOT have running water inside!!! And it's not that they don't have money to do the indoor thing.
