Tool Talk Discussion Forum
electrical panel near stove
Raynee
06-22-2006 13:19:22
hi, here's my question, I want to know is it safe to have your home stove located on the opposite side of the wall where an electrical panel is located? the wall is your standard 2x4 stud wall
buickanddeere
06-22-2006 17:29:19
 Re: electrical panel near stove in reply to Raynee, 06-22-2006 13:19:22
A wood stove needs to have a thermal barrier to protect the wall, electrical panel or not. The wooden studs maybe fine for years but they get super dry in the heat and chemically change. Eventually you will have a wall fire start when the wood is well below normal ignition temp.
John T
06-22-2006 16:54:12
I cant say know what any of your local building codes may require, but if the panel itslef meets any NEC mounting requirements, I dont see much of a problem if on an opposite wall a stove is placed, provided it meets any space or clearance requirements itslef.
John T
Bus Driver
06-22-2006 14:29:31
Panel cannot be in an clothes closet. It must have minimum clearances in front and above the front of it after installation. Those are the main restrictions.
Chris(WA)
06-22-2006 13:47:08
If the stove has the approved heat shielding and exhaust(wood or pellet stove)I do not see why it would be a problem. If yopu are talking about a range it should be no problem either. It is imperative that the stove is installed properly.
raynee
06-22-2006 14:32:52
 Re: electrical panel near stove in reply to Chris(WA), 06-22-2006 13:47:08
thanks for your reply it's a range top small 24" my fridge is currently in the place where i want to put my stove but, it occured to me that maybe because it will obviously emenate heat that maybe i needed to be concerned. Thanks
van robinson
06-22-2006 19:26:41
 Re: electrical panel near stove in reply to raynee, 06-22-2006 14:32:52
If it is a range top, there is no problem. It will not generate enough heat to pose a problem.
