Tool Talk Discussion Forum
sand blasting
grj27882
06-21-2006 12:41:14
can you tell me what i can buy to do some sandblasting on some old tractors and trucks i want to restore. don"t have a lot of money to spend but don"t want to buy something so cheap that i just end up wasting my money. also what kinda air volumne do i need. is a 7hp-60gal compressor enough.
Rustyj14
06-23-2006 17:55:13
 Re: sand blasting in reply to grj27882, 06-21-2006 12:41:14
Let me offer some advice! If you are thinking of sand blasting the paint off of a hood, or door panels--don't! the heat from the sand when it hits the metal will warp any large tin panels, such as hood, doors, trunk lids, etc. The sand heats up from friction, and it doesn't take long to get it very hot!~ how do i know this?? don't ask---- Hand or machine sanding is the way to go for those places. Sand blasting is for heavier steel parts, or for hard to reach places, like in door bottoms, or in hard places to hand or machine sand! I'd say--blast only the rusty places, don't try to remove all of the paint--use a product called "Aircraft Stripper, a commercially available product at auto parts/ paint stores. After it has done its work, hose it off with the garden hose, let it dry, clean up the edges, wash with mineral spirits, or a cleaning material, such as "Pre-kleeno, available at auto paint stores! Sand the surface with a medium grit sand paper, Then apply the primer, to keep the metal fresh for painting later. you must also blow all of the grit out of every place where it could "hide", because it will make its presence made as soon as you start to apply the first coat of primer! Believe it! For doing the sand blasting, i used a pair of goggles, paper, or painters canister masks, a full face plastic shield, a hat that fits over the ears, shirts that button at the neck, and sturdy work boots, and gloves! you'll sweat in the "get-up", but there's nothing worse than having to pick sand out of yer ears, mouth, eyes, and other, unmentionable, places! And, that was only for light jobs! Rustyj
Richard Scott
06-22-2006 14:56:52
Use plastic media on paint & sand on rust for fastest results. Don't expect plastic media to touch rust.
Butch(OH)
06-22-2006 05:18:17
There are no freebies in the world of sandblasting. CFMs equates to work getting done. The nozzle has to be so big or the sand won�t go through it. The sand going through the nozzle quickly wears the hole bigger so it takes a lot of CFMs to blast with a new nozzle and more and more until you have to replace it. You can work in short bursts from a smaller compressor or work continuously with a larger unit, how"s your patience? To give you and idea what I am talking about with the smallest nozzle that sand will go through without constant plugging my 6.5 HP rated Coleman (cant remember CFM but about 10) will allow me to blast about 20 % of the time, the rest of the time I am waiting for pressure. Using my 100 CFM Jaeger compressor I blast continuously and it is cycling on and off so Id guess somewhere about 50 CFM would be needed for continuous use, maybe one of the scientists here can help with that? Id guess it would take an hour or better to blast a WD Allis fender with my shop compressor but 15 minutes or less with the 100CFM unit. As somebody else said forget any siphon type blaster no matter what the hype, they are dead slow to use and will require roughly twice the sand to do the same work. You need a pressure vessel blaster. It can come from Harbor freight as long as you can get replacement parts for the nozzle, TSC also sells same type units from China. Bigger blasting unit does not blast faster given same size nozzle, you just have to stop and fill more often. Do get one with a �dead man� valve
CnKS
06-21-2006 16:55:30
HP doesn't mean much as the 7 hp is likely peak hp. You may have as much as 5 continuous hp, or less. CFM is the rating you need. For items of any size you need about 15 cfm at 90 psi. Mine is 24 cfm at 90 psi and is slow. Forget the siphon feeds and get a pressure blaster. You can match the nozzle size to the cfm, so that the compressor can keep up. Yours will work, but it will be slow. The less the cfm the more sand, or whatever, you will use. I have taken things to a commercial blaster with a 300 cfm unit. He uses a lot less sand than I do, and can do more in one hour than I can in four. If you do a lot of blasting with sand, you should get a supplied air system, charcoal masks will help, but don't filter out all the silica.
old
06-21-2006 15:24:42
I have 2 types of sand blasters. One is the preassure tank type and the other is a cheap Wal_mart one and I use the cheap one more then the $100 one. I think I payed $12 for the cheap one and the snad costs almost as much as the blaster did
John T
06-21-2006 13:29:58
gr, The kind we use is one of those cheap reservoir siphon type which tends to wear the nozzles fairly soon but gets the job done. As far as the compressor, they typically require a hefty CFM rating which seems more important and more necessary then the PSI we run them at, we tried using a fairly large (around 10 HP two cylinder two stage I believe) electric compressor a while but the blaster sucked the CFM and pressure from it badly, so now use a gas engine driven type 100 CFM or so at around 90 PSI and it DONT run out of CFM or PSI yayyyyy yyyyy A Grainger catalog can give the necessary CFM and PSI ratings for blasters they sell, but Im thinkin any smaller electric unit just aint gonna get er done !!!!! unlees you do a lil at a time n let the receiver tank replenish itself now n then
The blasters arent all that expensive, just a big tin can reservoir BUTTTTT TTTTT whats needed and can keep you from dying and allows you to see is a lrage forced air ventilated hood. Otherwise the lens fogs up, you cant see, and you breathe in sand and wake up dead OUCH
We used to use the regular sand blaster sand but the much cheaper white playground sand works BUTTTTT TT it says on the bag NOT for sand blasting so we may all die soon???
Let us know, GET A GOOD VENTILATED HOOD Do as the directions n experts say, NOT meeeee ee Im more into lectricity stuff ya know
John T
