Tool Talk Discussion Forum
Dryer problem
CEB
06-20-2006 11:59:19
I realize this isn't an appliance forum, but I thought their might be someone out there who knows something about appliances.
The wife's dryer won't heat up. Since we live in the middle of no where, I don't want to just call a repairman and spend $$$ on a 10-year old dryer. I assume the thermostat must be bad or could it be something else? Thanks for the help.
oliver28472
06-22-2006 10:57:00
 Re: Dryer problem in reply to CEB, 06-20-2006 11:59:19
Get yourself one of those blue and yellow reader's digest repair books. They cover many types of applicance repairs. You can find them at yard sales or flea markets. New ones can be had at Lowes for $31.00. I have fixed my washer and dryer using these for years. Your problem is most likely the heating element. Make sure you unplug the dryer before you start anything else or you'll be burnt too. Take the element to a used appliance place. They usually keep new ones on hand or can order for you.
John F in MD
06-21-2006 10:03:19
Sounds like one or both of the elements burned up. I had the same problem about 5 years ago on a 20 year old sears dryer. I found an appliance supply shop in the yellow pages. The element cost around 30 bucks I think. Took about an hour or so to fix it.
oldrustycars
06-20-2006 17:41:45
Link
Shawn Baker
06-20-2006 17:32:37
Ammana Dryer, they have a "thermal Fuse" one shot deal. Take off the front cover 2 screws on the bottom front facing the dryer on the left hand side in the back you'll see the element behind a peice of sheet metal, in the middle top half of that metal you'll see a device with two wires, one going to the device on the front, one to another device on the lower left of the element. Cost- parts stor $4, Maytag dealer $8, go to the parts store buy 2 and tape one inside- they only blow on Sunday
bradk
06-20-2006 17:49:03
 Re: Dryer problem in reply to Shawn Baker, 06-20-2006 17:32:37
A laundra-mat owner told me that he didn't allow people to use dryer sheets in his dryers.He said the stuff from the sheets would coat the element sensor and give false reading shutting down element.
Anyone else hear about this? ~brad
Stan in Oly, WA
06-20-2006 18:28:46
 Re: Dryer problem in reply to bradk, 06-20-2006 17:49:03
I hadn't heard that one, but my sister told me that an appliance repair man showed her that using those sheets puts a coating on the lint screen so that it will hold water. She took it out, cleaned the lint out of it, poured some water in it, and it didn't run through. That's got to be bad for air flow.
Stan
CEB
06-20-2006 12:26:08
Sorry----- it is electric. Where do find the heating element? Do I have to take the back off? Its an Amana.
Richard H.
06-20-2006 14:50:39
 Re: Dryer problem in reply to CEB, 06-20-2006 12:26:08
Here"s one for ya, on the exhaust side normally there is a circuit breaker that is only a one shot deal... it will not reset cuz it is tellin you to clean out your hose and vent. the diagram will say it is a fuse and it is. Get a test light or meter and read across each one and don"t be surprised at the appliance store for what they want to sell the new one for..
Richard Lisowski
06-20-2006 12:17:08
CeB,is it gas or elect ?. if elect. the heating coil may have burnt off at connection. Just stretch it a bit reattach to connector nut.
souNdguy
06-20-2006 12:15:54
If the dryer spins but won't heat.. check to make sure 220v is working.. that is.. that both phases of 110 are there.
Could be thermostat.. could be a broke heating element.
Soundguy
R Bedell
06-20-2006 13:25:46
 Re: Dryer problem in reply to souNdguy, 06-20-2006 12:15:54
How about a Brand Name and a Model Number..!!
