Tool Talk Discussion Forum
attach elec wire to block wall
paul
06-19-2006 00:44:22
In a barn (no livestock now, just storage) with red block walls, want to run some electric wire along the block wall. Is it allowed to attach the wire to the block, and what kind of staple/ thing would work for that?
Or would code require a furring strip, or other?
Block walls, concrete roof in this room, no wood in sight....
--->Paul
msb
06-19-2006 13:51:21
 Re: attach elec wire to block wall in reply to paul, 06-19-2006 00:44:22
Hi Paul.If you use conduit then I would use PVC.It goes up much faster.I would also use the clik or klik fastener clamps and hang them with plastic anchors.They snap together with a pair of pliers. The EMT metal conduit is very expensive these days and rust could be problem down the road in a barn.I would use THNN individual stranded wire.It is much easier to work with than either solid THNN or romex wire and will,give you more wire capacity if you decide to add another circuit later.
Richard H.
06-19-2006 10:30:49
Sorry I posted before I read your post again.There is no furring strips needed, but I would use insulated 1 hole straps to tie it up there with plastic anchors in the joints. Richard
Richard H.
06-19-2006 06:45:16
One option you have is to use AC (armored cable), it is like romex with a flexible metal jacket. It is an upgraded version of the old BX. Plastic anchors , one hole straps and metal J-boxes. Richard
MarkB_MI
06-19-2006 02:52:56
Run it in conduit. It sounds like it will be exposed on the face of the wall; that's no place to run Romex.
You can attach the conduit clamps with Tapcon screws or any other sort of anchor suitable for concrete.
van robinson
06-19-2006 01:44:57
Paul, I would run it inside of a conduit, just for protection from damage and mice. Mice love to chew on wire. If you are planning on using romex, you can easily pull it in a short run of conduit. You can use plastic anchors to secure the conduit to the wall. But if you want to use just wire, you can use one hole conduit straps and plastic anchors to hold it to the wall.
Slowpoke
06-20-2006 00:14:57
 Re: attach elec wire to block wall in reply to van robinson, 06-19-2006 01:44:57
Is it legal to run Romex thru conduit?
Raymond Bagwell
06-21-2006 22:13:23
 Re: attach elec wire to block wall in reply to Slowpoke, 06-20-2006 00:14:57
Only for physical potection in short runs. Not legal to run it on a concrete surface either unless run on boards.
