Tool Talk Discussion Forum
Speedaire Compressor Problems
vwtoys
06-16-2006 08:47:21
I got a Speedaire 2Z630C compressor from a friend who said the motor or compressor is dead.. I found one of the Capacitors bad on the motor. the 15MF one. I took off the wires and didn"t bother to make note of the way the were hooked up. Can someone tell me ? One wire goes from the starting cap over to the running cap. the other two come in under each cap. Its the wire between them I"m not sure where to hook! The 15MF has 3 wires the other only two. It"s a 2Z630C compressor, Motor is Dayton 5Z185, 2.9Kw? HP? Motor ref # R60712 230v 15FLA, E47479, MOdel?Lr22132
The prev. owner scratched out 230v and put 480v. Does anyone know how to get back to 230v. It has a three prong plug with one prong going north/south and the other east west, and the ground below. THanks!
R Bedell
06-16-2006 15:00:56
 Re: Speedaire Compressor Problems in reply to vwtoys, 06-16-2006 08:47:21
Go to this link. There is a "typical" wiring diagram for a CSCR motor.
Bob
06-16-2006 10:13:20
Dayton is a WW Grainger brand.
If you go to www.grainger.com, you should either be able to find diagrams for the motor on-line, or email them for help.
