Tool Talk Discussion Forum
copper brazing alloy
bil b va
06-15-2006 10:47:13
can copper brazing alloy ( used for copper to copper brazing ) be used to join copper tubing to a brass fitting ? this is for air conditioning and refregeration work . if not what should be used ?
Charles (in GA)
06-16-2006 16:54:17
 Re: copper brazing alloy in reply to bil b va, 06-15-2006 10:47:13
Due to all the confusion you are getting, I'd go to the Copper tube handbook, published by Copper.org and see what it has to say. It will list what solders and brazes can be used in what combinations of fittings for what psi limits and for what sizes of tube, etc. Very through.
Link
CJ-maybe
06-16-2006 08:39:49
Yes,use an alloy,Silvaloy or the like.Silver solder if you want problems.
R Bedell
06-16-2006 10:48:30
 Re: copper brazing alloy in reply to CJ-maybe, 06-16-2006 08:39:49
I am a HVAC - Refrig Tech. I have used Silver Solder on copper to brass joints for 35 plus years with NO PROBLEMS...!!!!!
CJ-maybe
06-16-2006 13:50:13
 Re: copper brazing alloy in reply to R Bedell, 06-16-2006 10:48:30
I'm not trying to rile anybody,I'm also in the trade and have repaired to many leaks.I didn't say always,either-just my experiance/opinion.Silver solder has been used a long time,then a shift to brazing using an alloy as a stronger weld.With pressures going up more important than ever.Manufacturers (maybe not all)guidelines are asking for 5-6% or 45% silver alloy.
R Bedell
06-16-2006 03:06:36
NO.....you have to use Silver Solder
Steve U.S. Alloys
06-15-2006 18:58:26
Yes
mjbrown
06-15-2006 12:16:49
Silver solder?
