Tool Talk Discussion Forum
Parts washer paint thinner
thebigron
06-14-2006 19:09:57
Have had 20-25 gallons of Wal-Marts finest paint thinner in my parts washer for a couple of three years. Seems like its beginning to smell like something "burnt" or maybe its turning rancid. Any thoughts on how to refresh the lot or should I just dump it?
chuckinnc
06-16-2006 07:30:50
 Re: Parts washer paint thinner in reply to thebigron, 06-14-2006 19:09:57
Try a cup of vinager, cooks add a teaspoon to califlower, brocili or other smelly
stuff so they will be odorless while cooking. Who knows it might work here also.
thebigron
06-15-2006 20:12:50
I'll probably try the wicking idea. Can't do no harm I would think. Thanks for the ideas.
Mike M
06-15-2006 04:18:47
Got any brush piles to burn ?
Stan in Oly, WA
06-14-2006 21:10:41
Hi bigron,
I used to save thinner in clear plastic bottles after washing out paint brushes with it. Almost anything except varnish would settle out of it, eventually forming a solid layer at the bottom so that the clear thinner could be poured off without needing to be filtered. Never could get rid of the nasty smell though. Eventually it would smell so bad that the savings wasn't worth the unpleasantness of working with it. Post your results here if you try the wicking process, especially if it generates cleaned thinner that smells better than the stuff you started with.
All the best, Stan
msb
06-14-2006 20:21:54
Takes a while ,but you can put a piece of old hay rope in it and drape it over the side of the container and put the other end into a container placed a little lower that the first container.The thinner will siphon out and down the rope,cleaning it in the process.No need to toss it.
