Tool Talk Discussion Forum
Super 99- press pix
JMS/MN
06-14-2006 12:58:33
third party image
This is the top frame detail- 12 inch I-beam with three additional layers of half-inch sheet steel..... ...I'd appreciate advice on how to post multiple pix!!!, now that I might have the single posting figured out.
super99
06-16-2006 16:49:33
 Re: Super 99- press pix in reply to JMS/MN, 06-14-2006 12:58:33
Thanks for the pic's, nice looking unit. Chris
dr.sportster
06-14-2006 13:55:03
Nice job.Pretty heavy duty.Got some paint to spiff it up?Nice bender also.
ebbsspeed
06-14-2006 13:12:49
Doesn't look like that will flex too much..... .
TimV
06-14-2006 13:15:59
 Re: Super 99- press pix in reply to ebbsspeed, 06-14-2006 13:12:49
(grin) I was thinking the same thing. Impressive amount of steel in that press! Looks like it would be just the ticket for my garage--I don't need a press often, but when I do, it sure would be handy to have. Also, with a few home-made dies, you could do flat stock forming a lot easier than the old "heat and hammer" method.
JMS/MN
06-14-2006 17:04:40
 Re: Super 99- press pix in reply to TimV, 06-14-2006 13:15:59
Paint is on the to-do list, along with the overhead crane. Dies for bending are also in the plan- that's another advantage to the interchangeable pin idea. Pins slide out on the back side of the press, not the working side- no danger of blowing into your face. Various size pins eliminate jerry-rigging an intermediary pin to match a shaft- which often blows out towards the operator. Recently changed the jack to a 30 ton, and with upwards of 500 lb of steel in the frame and bed, I think it could take 60T, by comparing this frame to a lesser built one in a local shop.
TimV
06-14-2006 17:51:34
 Re: Super 99- press pix in reply to JMS/MN, 06-14-2006 17:04:40
Hey--I always go by the First Rule of Arctic Engineering--"if it works, it's done". Paint is strictly optional on something that's not going to get rusty setting out in the weather. I agree that I've seen presses rated at 60 tons that aren't as massive as this one! Of course, I've also seen electric motors rated at 6 HP with a 1/2" shaft and 110-v power input....
