Paul, the design of the RECEPTACLE, including the size n shape and Vertical or Horizontal orientation of the female slots, is for certain current and voltage ratings and so that the proper and matched accompanying PLUG(s) will fit into them. Typical of residential 125 volt 2 pole 3 wire grounding type Receptcles are: NEMA 5-15R with the two vertical slots rated for 125 volts at 15 amps NEMA 5-20R with the two vertical slots but the one is "T" shaped as you noted. The NEMA 5-15P Plug fits in EITHER Receptacle The NEMA 5-20P Plug ONLY fits in the 5-20R Receptacle, cuz the one blade (fits the T) is Horizontal. It will NOT fit in the 5-15R THESE ARE NOT THE SAME as the older 2 pole non grounded NEMA 1-15R Recpetacles with only the two Vertical slots. THESE ARE NOT THE SAME as 2 Pole 3 wire grounding NEMA 6-15R 15 Amp or 6-20R 20 Amp Receptacles rated for 250 Volt which have different blade configurations. Its often the case where higher quality and/or higher amperage loads n devices could be used that the NEMA 20R Receptacles are installed, even though its often only the more standard 5-15P plugs that are plugged into them. If someone happened to have the NEMA 5-20R Receptacles (with T) lying around or even if they wanted to purchase higher amp rated Receptacles would be reasons they were used, as the more standard and typical 15 amp NEMA 5-15P Plugs still fit them. Hope this helps, yall take care n be safe now n God Bless John T Retired Electrical Engineer
