Sandblaster ? What size?
Ossie Smith
03-10-2001 18:37:34
I have a Lindsay 80 cfm compressor and want a good sandblaster that matches this compressor. Anyone that can help me with the selection of a good fast sandblaster to blast farm equipment I would greatly appricate it. I keep getting different stories from folks and am totally confused and I don't want to buy junk or equipment that will not do a good "FAST" job. I don't mind paying for it I just don't know what to buy. Thanks for the help .
Franz
03-10-2001 20:46:54
 Re: Sandblaster ? What size? in reply to Ossie Smith, 03-10-2001 18:37:34
With 80 cfm, you should be able to run a 3/16" nozzle on a pressure pot blaster. I ran a Lindsey 100# pot with a 1/4" tip from my Jeager 125 for hours, and could quickly tell when the tip needed replacement by how hard the compressor ran, and how well it removed what was being blasted.
A real easy way to determine how large a tip you can run is put a pipe cap on the end of your hose and see what pressure your machine can deliver with a 3/16 hole, then drill it out to 1/4". Depending on what you're blasting, you'll want to run between 60 and 100 psi. The main difference in the size of the pot is how often you want to fill it back up.
Ray,IN
03-10-2001 19:27:03
I would email Lindsey, and request that info.If they no longer exist, try another mfgr.
