Tool Talk Discussion Forum
Sweat joints
woodbutcher
06-07-2006 08:09:46
I have a buildup around a couple of 1/2" sweat joints on water lines around the water heater. It is blue and powdery. I have had to replace one joint where this happened, but I don't know that this was the cause of the leak.
Is there any way to prevent this from forming?
Butch
farmered
06-08-2006 04:57:39
 Re: Sweat joints in reply to woodbutcher, 06-07-2006 08:09:46
I'm surprised that no one mentioned dielectric couplings. These should be used on all water heater installations to isolate the tank and prevent the corrosion you describe. Ed
Stan in Oly, WA
06-08-2006 15:26:33
 Re: Sweat joints in reply to farmered, 06-08-2006 04:57:39
Hi Ed,
Butch said the corrosion was at 1/2" joints around the water heater. I'd be surprised if the main intake or outflow lines were 1/2" copper, although I've seen worse. I figured they were branch lines from 3/4" copper only because it's rare to see 1/2" copper coming directly out of 3/4" steel. Nothing prevents anyone from doing it that way, I just haven't seen it much. If my guess at the configuration is right, that makes the question whether the lack of a dielectric can cause corrosion in a copper to copper joint some distance from the copper to steel source. I'd say no, but that's only a semi-educated guess, and a little semi-education can be a dangerous thing.
All the best, Stan
jeffcat
06-07-2006 11:38:47
Lots of old timmmmmers, just had to use plenty of acid soilder. I know about this from my folks farm. Hint, hint. I have seen where a "plumber" will not clean the pipe with a little 4 oooo steelwool to make it nice and clean. Yup, let the acid do the job. Use the correct soilder and I like to wipe the joints with a dry cotton rag while it is still liquid. The true old timmers could do it with their BARE hands! By the way, plumber comes from Romean and means lead as in working with lead pipes.I always use Nocrode in the little white tin cans. Have never had any trouble. Second thought, you could also have a little voltage to ground trouble too. Redo the pipes first and use a good DIGITAL meter not an anolog to measure for leakage. With the heater un hooked you measure from the pipes to a good solid ground and see if you get some kind of reading like 30 or 40 volts. Let us know. Jeffcat
Stan in Oly, WA
06-07-2006 08:19:02
Hi Butch,
It's from flux which was not wiped off after the joint was soldered. It's probably not the cause of the leak at that joint if the work was done less than thirty years ago, and probably not even then.
All the best, Stan
woodbutcher
06-07-2006 11:28:43
 Re: Sweat joints in reply to Stan in Oly, WA, 06-07-2006 08:19:02
Thanks, Stan. I appreciate the info. The leak was near a recirculating hot water pump. I think vibration might be the culprit.
Butch
Bill WI
06-08-2006 06:51:20
 Re: Sweat joints in reply to woodbutcher, 06-07-2006 11:28:43
Just another saying put in di-electric units between copper and galvinized. It'll migrate to more joints. Readily available (Fleet Farm) and relativly inexpensive.
