Hey Gene, I've used all 4 types out there and here's my take: 1. Original old stuff, can't find it, would probably give me cancer if I could anyway. What I liked about that stuff was that it dried quickly without leaving a residue, so you could paint without washing. 2. Kerosene, what I use now. Very economical, I just keep letting the stuff settle out and reusing it. Doesn't dry out it seems. I wind up scrubbing all parts in HOT water with Dawn dishwashing detergent before painting. Does a fair job of gunk removal. 3. "Heavy duty concentrated water based grease remover." It's really good dishwashing detergent in my opinion. Reasonably priced, but not very good at grease and oil removal. 4. Citrus water based grease removers. REALLY good stuff. The problem with this stuff is that is WILL load up and be DONE. Once it's saturated with emulisified gunk, you have to throw it away and mix up another batch. However, it really does a good job of leaving metal squeaky clean with no residue. When I used this stuff, I had my parts washer right next to a deep sink. I took the part right to the sink and used a kitchen sprayer to hose off the part with HOT water and then it dried quickly and was ready for painting. It can get sort of expensive. When you buy a parts washer be sure and check what the pump is designed to work with. If it's not rated to be used with a petroleum based solvent, you're stuck with detergent or citrus stuff. However, I used water based stuff with my petroleum compatible pump AFTER using it for awhile with solvent and it failed almost immediately. Not absolutely sure that was the cause, but, I'd buy a parts washer with a petroleum compatible pump, and then if you want to try the citrus stuff, go buy any cheap submersible pump, like come with tile cutters and such. As for the rust issue, I didn't have a problem. But, I was pretty anal about drying my parts off. If I get a sink set up next to a parts washer again, I'll probably go back to the citrus stuff. Tools
