Tool Talk Discussion Forum
Log splitter dies
RegoR
06-04-2006 06:07:53
8HP B&S - Starts faily easily and runs for 20 to 30 mins then suddenly dies. Sometimes it begins to miss for a few seconds before quitting, but mostly it just dies quickly. I've replaced the magneto, rebuilt the carb, replaced the carb, rebuilt the new carb, R&R in-line fuel filter, new plug (several). Nothing seems to correct the problem. I've run out of ideas and nearly out of patience. What ailing this old beast?
Thanks for any offerings,
Roger
jeffcat
06-05-2006 09:08:47
 Re: Log splitter dies in reply to RegoR, 06-04-2006 06:07:53
Does your engine have that low oil cutoff? Had one of them go funky. Jeffcat
RegoR
06-05-2006 13:33:15
 Re: Log splitter dies in reply to jeffcat, 06-05-2006 09:08:47
Hi Jeffcat,
I don't think so; it's about 15 years old, but I'll check.
Roger
Bob
06-04-2006 07:16:59
Have a test spark plug at hand, and when it dies, check for spark right away, to determine if it is spark or gas flow that is failing.
Thinking about this, Briggs aluminum block engines occasionally will have a valve seat come loose in the block when they got good and warmed up. The seat will then go up and down with the valve until the engine dies, and then when the aluminum block cools enough, it will hold the seat, and the engine can be started. I think it can happen to either the exhaust or the intake seat.
Below are some threads about loose Briggs valve seats. There is no "official" repair, but I have fixed several by "staking" the seat in place by making a series of centerpunch pricks in the aluminum block around the periphery of the seat. Saome of the threads below mention LocTite or JB Weld along with the staking with a punch, but I can't imagine either can do much good at the temperature the block operates at.
The seat should be re-ground, and the tappet clearance checked, and corrected, as needed, after staking down the seat.
Link
Link
http://forum.doityourself.com/archive/index.php/t-227413.html
RegoR
06-05-2006 08:03:11
 Re: Log splitter dies in reply to Bob, 06-04-2006 07:16:59
Hi Bob,
Thanks for the reply and suggestions. I'll try the extra spark plug test after it dies.
I forgot to mention that after quitting, it starts right back up again, only to repeat the cycle 20~30 minutes later. I've been "dealing" with this for several years. I'll look into the links you provided.
Roger
Bob - MI
06-04-2006 07:07:25
Two things come to mind here, one being the vent in the fuel tank and the other being a bad points condensor. Beyond that if there"s a kill switch you may want to look at loose wires or possible a bad connection someplace. Heat and vibration may be affecting the circuit.
Good luck finding the gremlins.
RegoR
06-05-2006 13:39:25
 Re: Log splitter dies in reply to Bob - MI, 06-04-2006 07:07:25
Hi Bob,
It's a fairly new tank & cap: the original tank was damaged beyond repair at the filler opening. You got me on the points and condensor in that I don't remember when I serviced them last. I will look into that.
Roger
