Tool Talk Discussion Forum
Wanting to salvage pistons
ldj
06-03-2006 20:08:20
My farmall cub compression got so low that it will run only a few min. and fowl plugs.Leak down pressure is only 25 over 80. Took pistons out and rings are worn real bad, .095 end gap AND .008 side clearance on ring land and it is tapered a little. Piston and bore fit is acceptable and the inserts and crank is good. I don't want to split tractor and do a real rebuild, I just want to fix and not spend the money for pistons just because of the ring lands.I am thinking about machining out the land enough that I can use the old ring rails from the oil rings as shims for the new rings I get. Does anyone know if this will work and if so would it need to be done on both or only top compression ring? L.D.
Bus Driver
06-04-2006 13:45:51
 Re: Wanting to salvage pistons in reply to ldj, 06-03-2006 20:08:20
From memory, the cylinder wall wear must not be more than about 0.005 for reringing with the same size rings and pistons. Greater wear requires rebore.
Earl-IL
06-04-2006 09:39:38
You can cut the top grooves in a lathe. The top side of that groove always tapers up. New rings & Hasting spacers will make the pistons serviceable. Earl
jdemaris
06-04-2006 07:45:42
I've done many of them and they worked out fine. Hastings sells the shims - in any quantity. They sell two types - one type requires special machine work and the other does not. The last set I did was a four-cylinder gas engine and the shims cost a total of around $12. I had a local guy cut the top piston grooves for a total of $35. Hastings also sells special regrooving equipment - but I doubt you'd ever find anyone that has it - today. Years ago it was standard procedure to rebuild pistons if possible - we'd knurl the skirts, bore the pin-holes oversize, and recut the grooves. I was impressed with the people at Hastings. I called them on the phone, and they were willing to sell me anything - shims or piston rings - for any application - in any quantity instead of having to buy sets. You can read their article about fixing ring-grooves - but keep in mind - you do NOT need the special cutter if you buy their staight-sided repair shims. Look at: Link
Jerry/MT
06-03-2006 22:15:18
Why not review the specs on rings of the same diameter as your piston requires and see if you can find a set of rings that are thicker that might fit. Then you can machine the lands to fit the new thickness. You might be able to go onto the Hastings web site or one of the other brands and get the specs or I'm sure a machine shop could help you do this. Your shimming idea may work but I would be concerned that when the gas pressure forces the oil control ring out against the cylinder wall( they're just designed to wipe off the oil not hold pressure), it might just bend around the edge of the land. In that case you'd be in a bigger fix than you are now. Really the sure fire fix, if the lands are out of spec, are new pistons. You know that will work. What do they cost?
Bob
06-03-2006 22:08:29
Dave Reed has wider rings, or any shims you might need. Here's his site:
Link
http://www.dol.net/~dave.reed/otto.html
