Hi, It all depends on the pump and what motor it was designed to operate with. Actual pump speeds can vary quite a bit depending on capacity and longevity desired and available motor horsepower. Typically, the pump speed would be somewhere between 500 rpm and 1500 rpm. If the motor is undersized for the speed selected, it will be overloaded before the cutout pressure is reached. Here's what I would do, not knowing any more than you have indicated: 1. Assume a pump speed of between 700 and 800 rpm. Using a 1725 rpm motor and a 3.5" diameter drive pulley (and 8" dia pump pulley), that would put your pump speed at 3.5/8.0x1725 = 755 rpm. That's a reasonable starting point. 2. Run that combination and monitor motor current with an ammeter as the tank pressure increases. If you get to full load motor current (as indicated on the motor nameplate) before you get to, say 125 psig, you will know that your motor is underpowered for the speed selected. You would then have two choices - either get a bigger motor or slow the pump down by using a smaller motor drive pulley. Of course, if you slow the pump speed down, you will also reduce the pump cfm capacity proportionately. Rod
