Bob, first of all, as far as the two hot phase wires, L1 and L2 on a 120/240 Volt Single Phase 3 Wire typical Residential Service IT MAKES NO DIFFERENCE which phase wire connects to which phase (NOT ground) plug terminal, its 240 volts AC between the two and assuming the welder uses ONLY 240 volt, it requires no Neutral (grounded conductor), just the two hot L1 and L2 phase wires plus the equipment safety ground. The 2 similar plug legs would be the two phase wires while the stand alone or circular type would be for the equipment safety ground (often green or bare). CAUTUION NOTE: You have to use a plug,,,,and a receptacle,,,,, and branch circuit feed wires,,,,, ,,,, and a circuit breaker rated to handle what the welder requires!!!!! !! Some AC Buzz Box welders similar to what you describe require 50 amp service n receptacles n wiring and branch circuit breakers while smaller welders may only require 30 amp service WHAT DOES YOUR WELDER REQUIRE ????? ????? ????? ??? Once you know that all you have to do is insure that alllll lllll the branch circuit components being the plug,,,,the receptacle,,,,, ,the branch circuit wire sizes,,,,, ,,and the circuit breaker are suitable for the welder, be it 30 amp or more likely 50 amp service. Once I know what the welder requires, be it 30 or 50 amp service, I can advise you whats required. John T, retired Electrical Engineer
