Tool Talk Discussion Forum
Measuring Bolt Circles
dr.sportster
05-30-2006 15:12:59
How can you accuratly measure a bolt circle when no two holes are across from each other?
John Niolon
06-01-2006 15:15:38
 Re: Measuring Bolt Circles in reply to dr.sportster, 05-30-2006 15:12:59
here"s something that might help
john
http://www.midatlanticmotorsport.com/bolt_circles.htm
Don-Wi
05-31-2006 22:01:21
I'm guessing you're asking about either a 5 or 9-bolt pattern? for 5 bolt, measure from the outside of one hole to the center of the 2nd or 3rd hole, it'll get you close enough. I'm not sure about 9 bolt, but I think it would be about the same principal. Simpler is better, don't bother with all the math and trig. Like the other guy mentioned, you can also measure from the approximate center to the center of the bolt hole, and multiply by 2.
Donovan from Wisconsin
bryan in Iowa
05-30-2006 16:42:40
For car rims, measure from the edge of one stud hole , skip one and measure to the center of next one ,,,ie 5 bolt rim , typical 4 1/2 on 5 , 5on 5 , so on
landlord7012
05-30-2006 15:54:51
for a rim measure with a caliper from the edge of a stud hole to the edge of the center hole. add that measurement to 1/2 of the stud hole diameter and 1/2 of the center hole diameter multiply the result by 2. thats your bolt circle diameter.
landlord7012
05-30-2006 15:47:22
Carr-Lane has a fantastic "Chordial constants" chart that you could use to back-figure you bolt circle. By measuring two holes closest and then furthest apart you could apply some basic trigonometry as well.
ll
Waltmo
05-30-2006 15:43:58
Find the center of the circle and measure out to the center of the bolt hole. This will give you the radius.
More information on what you are measureing might be helpful.
Waltmo
