Tool Talk Discussion Forum
Shop Lighting...Side Walls
Glenn F.
05-30-2006 13:39:22
I'm chipping away at this wiring, insulating, finishing off project. My shop is small(22x34), with not an inch to waste. I am installing Many florescent fixtures in the 8' ceiling. In lighting the side walls, how close to the ground should the lights be? I'll be using 4' 2 bulb fixtures here. The shop is used for welding, mechanical, carpentry, etc.
Thanks, Glenn
xragman
05-31-2006 07:01:33
 Re: Shop Lighting...Side Walls in reply to Glenn F., 05-30-2006 13:39:22
In my shop [30 X 36 ] I mounted 20 of the 4 ft. 2 bulb fixtures on the 8 ft. ceiling in 3 switches. Also 1 unit over each workbench just high enough to clear my head. 6ft, 2" H T H
Ozlander
05-30-2006 19:45:25
You only have an eight foot ceiling. Put the fixtures as high as you can get them. You'll welcome the clearance.
