Tool Talk Discussion Forum
OT:Ceiling fan won't reverse
ReddTom
05-26-2006 18:39:32
I got aceiling fan thats been going the same direction for at least five years. I tried reversing it and it wouldn't go, even if I spun it by hand. So I gave up and now it won't go either direction. What gives?
Jay (ND)
05-27-2006 17:29:58
 Re: OT:Ceiling fan won't reverse in reply to ReddTom, 05-26-2006 18:39:32
You didn't get any serious answers so here's one:
Turn your fan around.
tn terry t
05-26-2006 18:57:12
most likely that little -silde switch has got dirty best fix ive found is to take it apart and spray exectra cleaner in the switch works about two thirds of the time only other thing is to replace the switch
RandyBee
05-26-2006 18:53:25
Work the reversing switch back and forth several times to clean the contacts. Do this with the power switch off. After working switch then try again. Your reversing switch is probably dirty inside.
