Tool Talk Discussion Forum
11hp Briggs problem.
Jay87T
05-26-2006 11:15:38
Hey guys I have a old walk behind that I cant get started, Seems like there is little or no spark. I replaced the ignition coil/points and condenser before winter, I had it running and was using it for a couple weeks now but now I cant get it started. any Ideas what I can check to pin point why the spark is weak or not there at all.
redboy656
06-06-2006 04:59:30
 Re: 11hp Briggs problem. in reply to Jay87T, 05-26-2006 11:15:38
if it has mag. points on the flywheel then use sandpaper to clean them off, and make sure the spaceing is all correct.
Jay87T
05-26-2006 17:50:13
K I think I fixed it never had a chance to fire it up yet today, The coil was abit 2 far from the fly wheel not producing enough of a spark.
Tom in TN
05-26-2006 13:01:21
Jay,
Does your mower have a kill/blade brake handle on it? I fixed a neighbor's mower a while back by replacing the cable that goes from the lever on the handle to the kill/brake lever on the mower. The cable had stretched to the point that it couldn't be adjusted enough to fully activate the kill switch.
Just a thought.
Tom in TN
old
05-26-2006 11:36:43
One of the first things to check is the points, they maybe burned or dirty, either will cause you problems. Also you might need a new spark plug
