Tool Talk Discussion Forum
REMOVING SILICONE CALK
n444
05-26-2006 07:22:10
Need to remove SILICONE CALK from stanlees steel stove pipe without Scratching it.
I want to return it to stove store to get my money back. IT REALLY WORKS WHEN YOU DON'T WANT IT TO !!!!!
Tim in OR
05-26-2006 20:42:24
 Re: REMOVING SILICONE CALK in reply to n444, 05-26-2006 07:22:10
Diesel, it dosen't take too much, and it will cause the silicone to start loosing its grip.
Good luck
Tim in OR
Vern-MI
05-26-2006 07:34:39
Try gasoline. Everytime I have used it around gas it seems to peel right off.
RustyFarmall
05-26-2006 10:14:12
 Re: REMOVING SILICONE CALK in reply to Vern-MI, 05-26-2006 07:34:39
Gasoline, acetone might work, or even rubbing alcohol. You might want to experiment with the acetone before using it.
Bernoulli
05-26-2006 16:18:06
 Re: REMOVING SILICONE CALK in reply to RustyFarmall, 05-26-2006 10:14:12
I use a heat gun to remove excess adhesives. I haven't tried it on silicone. Might be worth a try.
