CEMENT MIXERS
PAUL8N
03-08-2001 15:23:45
NEED ALL OPINIONS ON WHAT TYPE TO BUY, JUST USING IT TO MIX MORTAR AND A FEW PADS FOR WHAT NOT. THANKS, PAUL
BlueLight
03-15-2001 06:09:11
 Re: CEMENT MIXERS in reply to PAUL8N, 03-08-2001 15:23:45
I assume you mean the regular and not 3PH
type. I use the Red Lion with a 3.5 hp motor. You
can get them at home depot. You'll need the gas motor for isolated areas. I have the mixer rigged for electric or gas. Make sure you have at least 1/2 hp electric. I find that it is better to make your own support rod because they turn a little too fast for mixing. My rod has 6 notches to give me 6 mixing angles, 2 above and 4 below the standard bucket angle. This makes up for the speed. If your going to lower the angle, you'll have
to grease more often as it's a little harder on the bearing, but the shaft can take the added
torque as I have made a few walkways and a 20X20
ft slab so far without problems or wear.
Franz
03-08-2001 22:41:37
If you want to mix mortar, go with a paddle type mortar mixer. If you are going to mix concrete, use a drum type concrete mixer. Agrigate will bust the paddles out of a mortar mixer quick, and they're a pain to repair.
walt
03-08-2001 18:53:12
If you got access to 110volt, go electric. I put an ad in the paper wanted, mixer any condition..Got lots of replies.. Bought a beat up Sears for $60..
