Tool Talk Discussion Forum
Air Compressor Question
john-mi
05-25-2006 11:07:52
Does anyone know what the small plastic line from the unloader valve to the shut off switch is for or its function. Thanks.
john *.?-!.* cub owner
05-26-2006 19:46:28
 Re: Air Compressor Question in reply to john-mi, 05-25-2006 11:07:52
it is on the compressor side of the chck vlave, and runs to the pressure switch/unlader. whne the pressure switch turns off it opens a valve on teh end of the line to bleed off the pressure so the compresoor won't be under laod when it starts. They are a specka; plastic, if you tyr to use universal tubing it will fial due to heat and pressure. I learned the hard way.
Bob
05-25-2006 21:54:23
I think you mean to say there is a small plastic line from the CHECK VALVE to the UNLOADER VALVE on the pressure switch.
Charles (in GA)
05-25-2006 13:15:42
When the compressor shuts off you should hear air hissing from the pressure switch as the motion of opening the contacts also opens the unloader valve. If you do not hear the air hissing, the valve is most likely sticking and the compressor will not start up the next time, but rather stall out.
If the air doesn't quit hissing after a few moments, it means the check valve where the pump line goes into the tank, is not closing and is allowing tank air back up to the head and it leaks thru this valve also.
Charles
Vern-MI
05-25-2006 11:53:48
It unloads the air pressure in the compressor head via a valve at the switch everytime the compressor shuts off. That means when the compressor restarts it will be at a low starting pressur or atmopheric pressure and the starting torque will consequently be reduced. Without the unloading feature the motor would probably just stall and hum until it tripped the breaker.
