Tool Talk Discussion Forum
1086 air conditioner
Davin
05-24-2006 08:28:45
I have an international 1086 that needs a recharge of 134a refrigerant. I am unable to get the compressor to fire up to recharge the system. I have done this on trucks and use a piece of wire to bypass the low pressure switch to the compressor. The 1086 has one wire to the compressor. Any help would be appreciated.
Joe-Bob/IN
05-25-2006 17:03:50
 Re: 1086 air conditioner in reply to Davin, 05-24-2006 08:28:45
You may have a bad pressure switch. Usually doesn't take much to at least get one to kick in to pull the rest of the refridgerant in.
Cliff Neubauer
05-24-2006 09:22:16
I just went through this on our 1086 last week. There is one pressure switch on the condenser in front of the radiator and the other is in the top of the cab in front of the radio.
Bob
05-24-2006 08:50:04
With a long jumper wire, jumper from a source of battery power, to the clutch connector pigtail.
Bob
05-24-2006 09:06:02
 Re: 1086 air conditioner in reply to Bob, 05-24-2006 08:50:04
P.S....
Watch your charging gauges, so as not to overpressurize the system, if there's a problem, since you've bypassed the pressure switch(es).
